Help wanted to make this watchface perfect
CGB
Post by CGB »
This watchface { Belenkoks -Tomuxpl 10724}
is almost perfect for my needs but I live in the UK and I would like it to show miles instead of km and the date to show dd/mm not mm/dad, I did message ‘tomuxpl’ unsuccessfully so I thought someone here might be able to help. I have looked at editors but at 76 I am afraid of bricking my bip :lol
Sorry unable to post image or url
ebs
Been thanked: 6 times
Post by ebs »
Hi CGB,
As far as I know, the BIP's firmware only reports distance in kilometers, not miles, regardless of the settings in the app, so I think you're stuck with KM.
I can offer some help with changing the date format to dd (top)/mm (bottom).
Give me a few days to make the change. Meanwhile, send me a PM with an email address so I can send you the modified watchface.
Regards,
Eric
CGB
Post by CGB »
Hi Eric, thank you so much, PM'd as requested
Interestingly on the status page on the watch it shows miles, probably a conversion internally.
Regards
Chris
ebs
Post by ebs »
Hi Chris,
Yeah - for reasons I don't understand, BIP watchfaces can only display distance in kilometers, while the status page and app can be set to display miles.
A few developers have tried to create watchfaces that display miles but, as far as I know, no one has been successful.
I should have the modified watchface for you tomorrow or Wednesday.
Regards,
Eric
CGB
Post by CGB »
Eric, thank you so much, I received the new file and it installed perfectly
Regards
Chris
cooloutac
Post by cooloutac »
This watchface has correct number of miles. Amazfit customer support pointed it out to me. Can't a savy developer edit this one and see how its done? Its in the online section of app, one of the defaults. I'm gonna have to eventually try myself, this is nuts.
ebs
Post by ebs »
If someone knows how to get the .BIN file for that watchface, I could take a look at the .JSON file and see if there's a clue as to how they managed to display miles.
Regards,
Eric
cooloutac
Post by cooloutac »
ebs wrote: 01 Aug 2019, 13:26
Regards,
Eric
Just install it on your phone and then it will be in the local section of the mi fit app. If you need me to upload it let me know.
cooloutac
Post by cooloutac »
I think this is right one. let me know. Are you able to download it from here?
b01ccf0b9c91b7a6a3e19e0a199e0329.bin
(28.74 KiB) Downloaded 216 times
And I should note, the developer of the amazfit bip and cor watchfaces was denying this, but this watch face changes to kilometers or miles based on your app settings. Wondering if this one was made by an amazfit developer, which is probably why its one of their supported ones?
But then again maybe not because the other faces in the online list don't change according to settings. Only this one does. I would use it. but I like to have heart rate on screen too :(
For some reason I think the custom watch faces have the Mi or Kilometers as a static image I think, instead of dynamically changing. It just might not be done right. Same thing goes for the F and C in weather temperature, although at least the numerical amount for temperature changes according to settings even though the C or F symbol don't on most watch faces. I have a feeling distance level can also be changed automatically according to unit settings, but I guess this is more complicated then it looks.
Could it be that the watch editor publicly used is incomplete or limited? Could Amazfit be an anti American company? Is that why the app is called "Mi" fit hahaha. They have this one watchface just in case anyone brings up any questions or inquiries? They are definitely punning Amazon and fitbit, wonder if same goes for the imperial measurement system. I kid.
But seriously, am I being a traitor to my country not buying fitbit or garmin?
Someone needs to let the developer of the watch editor know he has some more reverse engineering to do, but I'm hoping you figure this out Eric.
ebs
Post by ebs »
I downloaded the .BIN file and tried to open it with AmazfitBIPTools Watchface.exe program.
It had a fatal error and was unable to open it.
Can you give me a link to the description page or forum post that leads to the watchface?
cooloutac
Post by cooloutac »
ebs wrote: 01 Aug 2019, 18:39
You simply open the mi fit app. go to online watch faces. and you will see it there, i posted a pic of it in this thread.
ebs
Post by ebs »
I would do that, but I don't use the MiFit app and I don't have it installed.
In any case, it can't be opened with the standard BIP watchface expander, so there's no way I can see the contents of the .BIN file.
Assuming that it is a valid .BIN file and can be successfully loaded on a BIP, that probably means that there's something in it that the Watchface.exe program doesn't understand. Without the .JSON file to look at, there's nothing that can be learned.
Has thanked: 437 times
Been thanked: 2141 times
ebs wrote: 02 Aug 2019, 00:26
you can use MiBandWFTool_1.3.6 (for Mi band 4) viewtopic.php?f=25&t=720 to Extract this bin file but .json after extract it have many unknow command so you can not pack to bin with WFTool for Mibip but if you edit and delete some command line in .json . it will work for WFtool for MiBip .
PS. my bin fix can not change km to ml . I think the problem is probably
due to watchface.exe of bip is still not able to pack and extract all the instructions correctly. so, it must wait for the developer.
Amendment in this problem first.
it may be usable.
Ex.
  "Activity": {
    "Steps": {},
    "Distance": {
      "Number": {
        "TopLeftX": 114,
        "TopLeftY": 155,
        "BottomRightX": 167,
        "BottomRightY": 165,
        "Alignment": "TopLeft",
        "Spacing": 1,
        "ImageIndex": 13,
        "ImagesCount": 10
      "SuffixImageIndex": 31,
      "DecimalPointImageIndex": 33,
      "SuffixMilesImageIndex": 32   <---------------  Watchface.exe  unknow  this command
All File unpack BIN by MiBandWFTool_1.3.6 (for Mi band 4)
Extract.bin by watchface.exe miband4.zip
(32.18 KiB) Downloaded 156 times
My .json fix
fix jason for create bin for watchface.exe mibip.zip
(52.51 KiB) Downloaded 182 times
cooloutac
Post by cooloutac »
Well darn I was afraid of that. Figures. I still wonder if amazfit engineers did this on purpose, to spite Americans. And they made this one watchface to pretend they didn't. I hope developer of the watchface editor can figure out the problem. Maybe someone can contact amazfit.
They are ignoring me now. They probably use this watchface to silence people, and then blame you guys as if it is your fault. I have linked this thread to them.
cooloutac
Post by cooloutac »
load it up man and see. Is it the only watchface in existence that change to kilometers or miles, depending on unit settings in the app,
and shows correct numerical value of miles? Again I use mi fit.
CGB wrote: 07 Jul 2019, 08:45
Mod.belenkoks by tomuxpl.DDMM,MI.bin
(25.73 KiB) Downloaded 201 times
- Date to show DD MM
- Can change KM to MI on Mi Fit and show in watchface
- If you want to Extract or Create this .BIN or jason Please use Amazfit watchfaces Tool version 0.1.0.10 viewtopic.php?f=29&t=782 Because have some command line The old watchface.exe cannot Extract or Create
Ex.
    "Distance": {
      "Number": {
        "TopLeftX": 25,
        "TopLeftY": 131,
        "BottomRightX": 95,
        "BottomRightY": 150,
        "Alignment": "TopRight",
        "Spacing": 1,
        "ImageIndex": 31,
        "ImagesCount": 10
      "SuffixImageIndex": 41,
      "DecimalPointImageIndex": 42,
      "SuffixMilesImageIndex": 99    <----- The old watchface.exe  don't know this command line
ebs
Post by ebs »
asoo,
That's great - I can finally see distance in miles on my watchfaces. Thank you!
Just to clarify - I don't develop watchfaces, I just modify the ones I like to be MM/DD and true 12-hour time.
Now I can change them to miles as well.
I wonder if there's a chance that the Watchface Editor by ilgruppotester will be updated to handle miles.
It reads the .json file without a problem, but only displays in KM. It still works fine for everything else.
Regards,
Eric
ebs wrote: 06 Aug 2019, 22:07
asoo,
Regards,
Eric
I hope too that the ilgruppotester will be upgraded to use with Amazfit watchfaces Tool
ilgruppotester can read the new json, but not 100%. Some sets of command line, if available in the new Jason, ilgruppotester Will not open and The program will close itself immediately.
Ex. code ( if have this in .json the ilgruppotester program will not open this json file )
    "AmPm": {
      "X": 0,
      "Y": 0,
      "ImageIndexAMCN": 0,
      "ImageIndexPMCN": 0,
      "ImageIndexAMEN": 0,
      "ImageIndexPMEN": 0
AvitoshChavan
Post by AvitoshChavan »
Great Information...
