How to edit a watchface(FOR BALANCE) downloaded from Zepp app store?
Omaradsl
Has thanked: 16 times
Been thanked: 8 times
Post by Omaradsl »
Good Morning, i have a request.
I downloaded a watchface directly from the zepp app store for my Balance. I like it a lot, but there are some elements that I would like to change, some to remove, in short, I would like to personalize it.
this is a photo, taken with a cell phone, of the watchface:
Is there a way to modify it by downloading it to the PC and importing it with the Sascha editor?
In the Zepp store watchface is this:
Thanks to all
Been thanked: 2086 times
Most watch faces in the "zepp store". It use script are encrypted and cannot be unpacked with Sasha's Editor. However, Sasha's Editor can unpack images. You can use the images after unpack, and bring it to create a new one.
You can download that watchface file you mentioned here.
https://mmk.pw/en/zepp_explorer/8519939/119988/
Omaradsl
Post by Omaradsl »
Thanks Asoo... hard work i see.
I extrated all images... but
you, who are much better than me, could you create for us?
Thanks thanks
Omaradsl wrote: 20 Feb 2024, 15:51
Thanks thanks
The watch face you're talking about uses "Editable elements" to change elements, which I didn't use. So this watch face I posted, I'm not sure how accurate it is. This watch face I made can be unpacked with Sasha's editor, so if you want to edit it further, Please do it by yourself.
This watchface I will not receive any fix or test , if you want to fix or test please do it yourself.
dXXISVOAXCAJIYqysKkilHDVhvppaHBS.zip
(405.25 KiB) Downloaded 175 times
Omaradsl
Post by Omaradsl »
Perfect, now i have a base for edit. Thanks bro.
Users browsing this forum: Google [Bot] and 0 guests
