REACTION_GOLD+ (GTR3 Pro)
Has thanked: 205 times
Post by amazfitfacesafrica »
Hello to forum. Can anyone from the creators with knowledge convert this watchface exactly as it is for GTR3 Pro because sasha editor can't convert it properly. Thank you.
https://amazfitwatchfaces.com/gtr/view/36530
Has thanked: 405 times
Been thanked: 2028 times
amazfitfacesafrica wrote: 02 Nov 2023, 15:22
???????? Have you tried converting and packed it yet?
Sasha's editor Version 9.1 can convert 100% correct
After you extract the file, you will see nested elements.
Don't be care about what you see.
You can convert to GTR3Pro right away, and pack it.
After pack the resulting .zip file will add user_functions.js and user_script_end.js. into the script and when used it will work normally just like GTR3.
Yes i already convert it but no all functions works and months dial shows 2 months in the same time. If i had success with convertion I wouldn't ask for it. And I also did the procedure to add the user_functions.js and user_script_end.js.
amazfitfacesafrica wrote: 02 Nov 2023, 18:46
I don't know why you can't.
But I tested it with Version 9.1 and can convert it to GTR3pro and it works normally.
If you use Version 9.1
You don't have to add user_functions.js and user_script_end.js
Because when you finish converting, you will get both files in the folder gtr3pro.
you just
unpack GTR3
convert
pack to GTR3pro
As for the display of the month frame, I will check again.
I convert it like you say and the result is this
Can you convert it for me and i test it if it's ok in my GTR3 Pro. Thank you.
amazfitfacesafrica wrote: 02 Nov 2023, 19:14
Thank for you issue report about Pointer month / week
issue is script can not hidden Pointer
Now i fixed
you can download again and convert by yourself
Or Download this
REACTION_GOLD_Puls_GTR_3_Pro.zip
(775.4 KiB) Downloaded 157 times
Ps.
This file cannot be converted to other sizes.
If you want to convert to another size Must use the original GTR3.
Otherwise, the pointer position (week/month)will be incorrect.
Thank you, months and day dial now works properly.
Lattenknaller
Has thanked: 57 times
Been thanked: 128 times
Post by Lattenknaller »
or you can try this one out:
https://amazfitwatchfaces.com/gtr/view/36552
not as colorful but closer to the original
