Been thanked: 2120 times
arturovivo wrote: 25 Sep 2023, 13:11
Thank you for this great tool. I am quite inexperienced so I wanted to ask if it is possible to open bin files as well as zip files.
Which Device are you talking about?
This program is used to edit devices that use ZeppOS as the operating system.
The standard dial file will have a format of .zip.
I'm guessing you're referring to the watch face that doesn't use ZeppOS.
If used, you can find editing tools here according to Device model.
viewtopic.php?t=1076
viewtopic.php?t=1888
Both of which will have watch face files as .BIN.
Please allow me to inform you.
Topic "Amazfit GT3 Series Watch Face Editor (GTR 3, GTR 3 Pro, GTS 3)"
Now changed name to "Watch face editor for Amazfit watch on ZeppOS"
for suitability with the program that supports editing more devices that use zeppOS than before
From SashaCX75's advice ;)
arturovivo
Post by arturovivo »
asoo wrote: 25 Sep 2023, 13:33
Thanks!!
rush2112
Has thanked: 119 times
Post by rush2112 »
wongkamfei
Post by wongkamfei »
Thanks @SashaCX75 for the watch face editor, every update sure will give big surprise with new functions added.
Now making watch face is easy and looks like professional.
Kruggerkill
Has thanked: 26 times
Post by Kruggerkill »
Great update, I love being able to place all those shortcuts, excellent work
AmazFit GTR4
Rafi87
Post by Rafi87 »
Hi
I want to ask if you could add a shortcut for light to your program?
in the evening / at night I tend to use the GTR 4 LE watch for lighting and I always have to pull down the top bar to turn on the light
there would be a shortcut so that I don't have to pull down the bar and just tap on the display and the display would light up
@Rafi87 I'm not quite sure what you're talking about. In the latest version there are buttons and they have the brightness menu launch.
If you mean the fleshlight (torch) then I'm not sure if it's accessible. I'll have a look and if I can I can try to add it to the button functions.
Rafi87
Post by Rafi87 »
SashaCX75 wrote: 06 Oct 2023, 09:49
this is what i mean
@Rafi87 I don't know how to run this programme from the code
Rafi87
Post by Rafi87 »
@SashaCX75 that's a shame, maybe you'll figure it out in time, think about it and maybe in a week or a month you'll be able to add it
Guydu91
Has thanked: 58 times
Post by Guydu91 »
I'm not sure I understood everything, but if it involves running the flashlight from a shortcut on the main screen, Melian Miko's site gives the following code {url: 'FlashLightScreen' , native: true}
Best regards.
@Guydu91 I think you've got it right. But Melian Miko wrote codes for mi band 7. This particular code doesn't work on amazfit. I checked only on GTR4, but I think it doesn't work on other models either.
ismaelf
Post by ismaelf »
Hey @SashaCX75 , love your program.
I was wondering if you could add two features that would make me stop having to create manual watchfaces with custom JS:
- ability to create hardcoded progress rings (not linked to any variable). A simple progress ring with custom width, start/end angle and color that was set to a custom hardcoded value to create the feel of the full ring that you have to fill with your goal progress.
- Being able to create variables that can store a simple string value and be changed. My idea that I currently do with custom JS is that when I change the pointer of my watchface (5 pointers with 5 different colors), the circles and rectangles drawn in JS change color to match the pointers.
Example of a watchface I currently do fully in JS that could be done in your app with those two things:
@ismaelf I have no plans to add such features.
Perhaps the ability to embed your own script in the watch face will help you. More details about it are written in the editor on the Tips tab.
You can write the code you need in a file and every time you build a watch face it will be automatically added to the watch face.
Version 9.1
Mirror
nikstgr
Post by nikstgr »
Thank you Sasha!!
smith725
Post by smith725 »
Ver 9.1 looks like some great new capabilities!
One thing I could not find - you mentioned "Added ability to create shortcuts for a set of images (IMG_LEVEL)." I have been all over the "shortcuts" option, and the various Image options, and nothing seems to bring some clarity on using this feature - which looks like it might be really useful. I did not find anything mentioning IMG_LEVEL...
Is it possible that I have to create an entirely new dial? That if I load an earlier version (before 9.x) then the new features will not appear?
@smith725 This is not in the shortcuts but in the additional properties of the widget displaying a set of images (IMG_LEVEL). The size of the label cannot be changed and it corresponds to the size of the images.
smith725
Post by smith725 »
Ah - and I was about to ask why some of these were grayed out - but then realized that not every "image set" corresponds to a logical shortcut.
I now realize I misunderstood (almost backwards) what this meant. It provides for a shortcut link for an area that is covered by an image, and it certainly cleans up duplicate dimension settings in "image sets" and a separate "shortcuts".
What I thought - likely because it is a problem I am trying to solve right now - is that this was a "shortcut TO SELECT sets of images". I am trying to find a way to have a shortcut switch image sets for "Day of the Week" to go multilingual rather than building multiple language variants. This is not for that purpose - I will keep looking.
smith725 wrote: 28 Oct 2023, 14:04
You can't do that in the editor.
You can use the hmSetting.getLanguage() command to find out the language and display different images depending on it.
You can also try to use the text_i18n property of the TEXT widget. But I don't know if it works on all models and if it works at all.
nikstgr
Post by nikstgr »
I just uploaded a WF with HR graph (it's not approved yet)
With the guidance of this link
https://docs.huami.com/docs/watchface/a ... _POLYLINE/
And I'm very happy with it 😄
smith725
Post by smith725 »
SashaCX75 wrote: 28 Oct 2023, 15:19
I absolutely get that I cannot just do this in the editor. I already have the image sets as widgets for all the languages, so - edit the Javascript after the build - I can create all the needed widgets. The visible property on each works to display only one, while the others are hidden. I can easily pick (in code) which widget is displayed by default.
Because the display widget includes an indicator for which language is being shown, the user experience was to just be "tap the day of week until the language is what you want". The idea was the check all the dayofweek widgets to find the one that was visible, make it visible:false, and make the next one visible:true.
Other normal shortcuts are working. Nothing blows up. I am creating a (larger, because fingers) separate shortcut widget that is completely transparent, and the event listener is to call the "next language" function. It just does not ever happen when I tap where the shortcut is (should be?). So - right now I am working through figuring out if I correctly called the function from the addeventlistener, or is my special shortcut hiding behind the displayed shortcut - either of these problems might (or might not) prevent my update from working.
@smith725 Widgets are created in the order they are written in the code. Widgets that are created later override those that were created earlier. If you make a widget invisible, it stops overlapping other widgets. Also with setEnable(false) you can leave the widget visible but not active, it will not interfere with the tracking of clicking widgets that are under it.
Personally, I prefer not to use addeventlistener and use hmUI.widget.BUTTON with a transparent image. In this case the button will always be displayed at the top, no matter what widget is enabled under it.
I would recommend to use hmSetting.getLanguage() to immediately set the language you want if it is in the list of available languages on the watch face.
smith725
Post by smith725 »
The hmSetting.getLanguage() does work better, except if the language is changed, from the phone or watch prefs, the display does not change. Is there a notification or event to determine the language has changed?
I have been seeing another oddity, maybe related? When my watch switches to AOD, at time 15:12 - 24hr mode, no leading zero, minutes follow. At first it displays "-1X2" ('-' is leading blank, X is the 5 and 1 both written to the same location). Once the minute cycles to 15:13, the watch then displays "1513". The problem it not fixed until a refresh happens at the minute change. I wondered if the Watchfacestools was setting up the API call incorrectly, but based on the API docs, everything there is perfect.
Will widgets not update - even to accept the changed visibility - until some event fires? In a device designed to conserve power by minimizing code running, that makes some sense. Am I missing a "display refresh" call that is reasonable to add when a display widget is updated?
(P.S. Just tested across a day boundary - nope. Crossing a day boundary does not force a 'pending update'.)
(P.P.S. If for no reason than to better understand this, I am rewriting this to only ever have one dayofweek widget, and tear it down and rebuild if a language change is required. We shall see.)
