SOLACE watchface for GTR3 Pro
- Has thanked: 205 times
- Been thanked: 5 times
Hello, can anyone convert this watchface for GTR3 Pro, StarScreaM already give his permission. Everything can be done for GTR3 Pro is welcome. Thanks and a big thanks to StarScreaM for this amazing and inovation watchface.
https://amazfitwatchfaces.com/gtr/view/32259
- Has thanked: 430 times
- Been thanked: 2132 times
This watch face using a custom and coded set of commands, I've unpacked and tried to make the functions look the same as the original.amazfitfacesafrica wrote: 16 Mar 2023, 13:21Spoiler
This watch face I created uses all the resources images from the original and some modifications. Therefore, this watch face may have some functions that are not the same as the original.
- seconds smooth have only seconds's circle
- This watchface have 3 element seconds analog in the same watchface , So some time 3 element seconds analog may be work a little different
I would like to tell everyon a little more.
Next, if any watch face is encoded " index.js " and have someone conversion request has been made I might not do it Because the owner of the encrypted instruction set must have his reasons to do that.
Link for T-Rex2 :
viewtopic.php?p=15161#p15161
Removed temp, leaving only the weather icon.
Link for T-Rex2 :viewtopic.php?p=15161#p15161
Amazing, it's work and seems just fine. Thank you so much. Can you take off weather icon and leave only current temperature with little bigger numbers font or take off current temperature and leave weather icon only but little bigger because they don't fit well together because it's tiny space for both and after all there is already a shortcut that takes you to the weather information. I am sorry who asks this but I don't have the skills to do it myself.
???? i test on my GTR3 it work normally.RobertV56 wrote: 17 Mar 2023, 17:01asoo, what a craftsmanship again ... beautiful but the circle of the seconds is not running on GTR 3, could you still get it working?
On GTR3 Pro circle seconds works very well and the other two second options too.
That's the problem with the second circle not working.RobertV56 wrote: 17 Mar 2023, 17:49Oh that would be it, I'm using the GTR3 wf's on my T-Rex 2, maybe that's why it's not running.
If I'm not mistaken, I found the information in A forum somewhere. In the text it says that the latest FW of T-rex2 has some changes.
Causing some functions to work unlike GTR3 / GTR3Pro
RobertV56
- Has thanked: 1 time
Thanks for your info asoo, but a pity that some things don't work then, although with this one all the second hands work on my t-rex 2
viewtopic.php?t=3444
The watchface that you talk about , it use smooth second Type 2 to create.RobertV56 wrote: 17 Mar 2023, 18:29Thanks for your info asoo, but a pity that some things don't work then, although with this one all the second hands work on my t-rex 2
Try this Version I change to use "smooth second type 2" , but it not smooth than type 1 but I think it maybe work for you
asoo, try to help me but he says that The look is written in code, when I unfold it I can't fold it anymore? What does this mean ?
I don't know what you mean .
This watchface use "custom script" it can not unpack by editor , if you use editor unpack the script will not show after unpacked , if you want to see the script . you must to unzip "watchface.zip " and see the script in file index.js
Thank you for Info. And if you want to make it like the photo I attach today how it's possible to do it ?asoo wrote: 01 Apr 2023, 15:06I don't know what you mean .
This watchface use "custom script" it can not unpack by editor , if you use editor unpack the script will not show after unpacked , if you want to see the script . you must to unzip watchface.zip and see the script in file index.js
As I can see, you need to make a new image with the same colors as your example. and replace the old image in the prototype
But which part of the picture should I do? You'll have to check and edit it yourself.
I mean battery dial orange like the photo with black pointer, date dial orange like photo, step progress bar orange with gray dot like photo and same white hands in hour and minute and orange seconds hand like photo. The others is same like your black orange version.
yes i understand
All that you said must be made new. to replace the old
The dial contains images. changing elements no matter the color or size You need to create a colored image. as you want to replace the original
If you do not create a new image I also don't know how to get what you want.
Thank you for information but I can't do it myself. Thank you anyway.asoo wrote: 01 Apr 2023, 16:09yes i understand
There is no way to do it this with sasha editor 7.1?
Now Editor is Version 7.2
Although the editor can't open watchface that use custom script,
ฺBut I think the problem is not with the program editor.
Because if creating a watchface However, it must be used The program editor to create the basic outline first. I think if you want to editing a watch face that it use custom script, the problem lies in trying to understand the commands in custom script and images that will be used to make the watch face.
I think the conversation is getting long and looping.
This is my last reply .
or until a different question arises
Good Luck , Have fun
