SOLACE watchface for GTR3 Pro
Has thanked: 205 times
Post by amazfitfacesafrica »
Hello, can anyone convert this watchface for GTR3 Pro, StarScreaM already give his permission. Everything can be done for GTR3 Pro is welcome. Thanks and a big thanks to StarScreaM for this amazing and inovation watchface.
https://amazfitwatchfaces.com/gtr/view/32259
Has thanked: 430 times
Been thanked: 2132 times
amazfitfacesafrica wrote: 16 Mar 2023, 13:21
This watch face using a custom and coded set of commands, I've unpacked and tried to make the functions look the same as the original.
This watch face I created uses all the resources images from the original and some modifications. Therefore, this watch face may have some functions that are not the same as the original.
- seconds smooth have only seconds's circle
- This watchface have 3 element seconds analog in the same watchface , So some time 3 element seconds analog may be work a little different
I would like to tell everyon a little more.
Next, if any watch face is encoded " index.js " and have someone conversion request has been made I might not do it Because the owner of the encrypted instruction set must have his reasons to do that.
Solac2B_GTR3pro.zip
(547.35 KiB) Downloaded 145 times
Solac2B_GTR3.zip
(507.37 KiB) Downloaded 106 times
Link for T-Rex2 :
viewtopic.php?p=15161#p15161
Removed temp, leaving only the weather icon.
Solace2BGTR3Pro_no_temp.zip
(560.39 KiB) Downloaded 103 times
Solace2BGTR3_no_temp.zip
(531.44 KiB) Downloaded 111 times
Amazing, it's work and seems just fine. Thank you so much. Can you take off weather icon and leave only current temperature with little bigger numbers font or take off current temperature and leave weather icon only but little bigger because they don't fit well together because it's tiny space for both and after all there is already a shortcut that takes you to the weather information. I am sorry who asks this but I don't have the skills to do it myself.
TRK88PL
Has thanked: 67 times
Been thanked: 40 times
Post by TRK88PL »
Awesome job asoo You are just great!
Thank you, asoo, it's awesome.
RobertV56
Post by RobertV56 »
asoo, what a craftsmanship again ... beautiful but the circle of the seconds is not running on GTR 3, could you still get it working?
RobertV56 wrote: 17 Mar 2023, 17:01
???? i test on my GTR3 it work normally.
On GTR3 Pro circle seconds works very well and the other two second options too.
RobertV56
Post by RobertV56 »
Very strange, it stands still for me, but then it must be my watch.
RobertV56
Post by RobertV56 »
Oh that would be it, I'm using the GTR3 wf's on my T-Rex 2, maybe that's why it's not running.
RobertV56 wrote: 17 Mar 2023, 17:49
That's the problem with the second circle not working.
If I'm not mistaken, I found the information in A forum somewhere. In the text it says that the latest FW of T-rex2 has some changes.
Causing some functions to work unlike GTR3 / GTR3Pro
RobertV56
Post by RobertV56 »
Thanks for your info asoo, but a pity that some things don't work then, although with this one all the second hands work on my t-rex 2
viewtopic.php?t=3444
RobertV56 wrote: 17 Mar 2023, 18:29
The watchface that you talk about , it use smooth second Type 2 to create.
Try this Version I change to use "smooth second type 2" , but it not smooth than type 1 but I think it maybe work for you
Solace2B-T-rex2.zip
(552.92 KiB) Downloaded 119 times
RobertV56
Post by RobertV56 »
Wooow amazing asoo, works perfectly, unbelievable how you always get it done. Thank you very much, very happy with it. ;)
Hello and have a nice weekend, can anyone with skills update Solace2BGTR3Pro_no_temp.zip with the same colour as in photo in dial and to hands, exactly the same. Thank you form help and support.
asoo, try to help me but he says that The look is written in code, when I unfold it I can't fold it anymore? What does this mean ?
I don't know what you mean .
This watchface use "custom script" it can not unpack by editor , if you use editor unpack the script will not show after unpacked , if you want to see the script . you must to unzip "watchface.zip " and see the script in file index.js
asoo wrote: 01 Apr 2023, 15:06
This watchface use "custom script" it can not unpack by editor , if you use editor unpack the script will not show after unpacked , if you want to see the script . you must to unzip watchface.zip and see the script in file index.js
Thank you for Info. And if you want to make it like the photo I attach today how it's possible to do it ?
As I can see, you need to make a new image with the same colors as your example. and replace the old image in the prototype
But which part of the picture should I do? You'll have to check and edit it yourself.
I mean battery dial orange like the photo with black pointer, date dial orange like photo, step progress bar orange with gray dot like photo and same white hands in hour and minute and orange seconds hand like photo. The others is same like your black orange version.
yes i understand
All that you said must be made new. to replace the old
The dial contains images. changing elements no matter the color or size You need to create a colored image. as you want to replace the original
If you do not create a new image I also don't know how to get what you want.
asoo wrote: 01 Apr 2023, 16:09
yes i understand
Thank you for information but I can't do it myself. Thank you anyway.
There is no way to do it this with sasha editor 7.1?
amazfitfacesafrica wrote: 02 Apr 2023, 08:51
Now Editor is Version 7.2
Although the editor can't open watchface that use custom script,
ฺBut I think the problem is not with the program editor.
Because if creating a watchface However, it must be used The program editor to create the basic outline first. I think if you want to editing a watch face that it use custom script, the problem lies in trying to understand the commands in custom script and images that will be used to make the watch face.
I think the conversation is getting long and looping.
This is my last reply .
or until a different question arises
Good Luck , Have fun
