Johnson070
Been thanked: 13 times
Post by Johnson070 »
Author
Johnson070
lvpokka
Tool description
  • All widgets support
  • Easy creation of watchfaces
  • Unpacking .bin
  • Support Mi Band 5
  • Support Mi Band 6
How to
2. Open MiBandWatchFaces.exe
4. Save file File => Save
Changelog
1.0.1.8 (2021-06-09)
- Fixed Circle Scale bug
- Fixed oneline date
- Fixed bug number size 0
1.0.1.2 (2021-04-22)
- Bug fixes
- (FIXED) Month/Date add
1.0.1.0 (2021-03-14)
Bug fixes
Add convert GIF to PNG frames
1.0.0.7 (2021-03-14)
  • Bug fixes
1.0.0.6 (2021-03-13)
  • Bug fixes
1.0.0.5 (2021-03-12)
  • Bug fix steps progress form
  • Fix circle scale form
  • Start work for languages
1.0.0.4 (2021-03-10)
1.0.0.3 (2021-03-10)
  • Bug fix status simple form
1.0.0.2 (2021-03-10)
1.0.0.1 (2021-03-09)
  • First release!
Screenshots
Support
https://paypal.me/j0hnson070
Download:
Click Assets
itaketapps
Has thanked: 9 times
Post by itaketapps »
brcisneros wrote: 17 Jul 2022, 01:04
Hey I need some help. I'm trying to make a face for the MiBand 6 from scratch and everything seems to be working ok on the editor, but when I install the face through Notify it doesn't show the day and date.
Any idea on why is this happening? I'll leave the code below and a link to the .bin file just in case.
"Background": {
"BackgroundColor": "0xF5F5F5"
"Time": {
"Hours": {
"Tens": {
"X": 15,
"Y": 80,
"ImageIndex": 0,
"ImagesCount": 10
"Ones": {
"X": 80,
"Y": 80,
"ImageIndex": 0,
"ImagesCount": 10
"Minutes": {
"Tens": {
"X": 15,
"Y": 140,
"ImageIndex": 10,
"ImagesCount": 10
"Ones": {
"X": 80,
"Y": 140,
"ImageIndex": 10,
"ImagesCount": 10
"UnknownV11": 0
"Date": {
"MonthAndDayAndYear": {
"OneLine": {
"NumberEN": {
"TopLeftX": 69,
"TopLeftY": 200,
"BottomRightX": 70,
"BottomRightY": 201,
"Alignment": "TopLeft",
"SpacingX": 1,
"SpacingY": 0,
"ImageIndex": 37,
"ImagesCount": 10
"DelimiterImageIndex": 47
"TwoDigitsMonth": false,
"TwoDigitsDay": false
"ENWeekDays": {
"X": 15,
"Y": 200,
"ImageIndex": 48,
"ImagesCount": 7
"Battery": {
"BatteryIcon": {
"X": 0,
"Y": 0,
"ImageIndex": 20,
"ImagesCount": 7
"Other": {
"Animation": [
"AnimationImages": {
"X": 0,
"Y": 236,
"ImageIndex": 27,
"ImagesCount": 10
"Speed": 100,
"RepeatCount": 10,
"UnknownTF4": 1
If you mean the absence of a day indicator, I recommend that you try to change "Number EN" to "Number" in the date input field.
Everything will be Ukraine
itaketapps
I have a problem with the analog clock. After creating the .bin file, the arrows disappear, although everything was displayed fine in the program at the time of creation. And that's not all. When I open third-party watch faces with working hands and save under a new name, they also disappear. (program version 1.0.1.18)
  "Background": {
    "Image": {
      "X": 0,
      "Y": 0,
      "ImageIndex": 0
    "Preview1": {
      "X": 21,
      "Y": 30,
      "ImageIndex": 8
    "Preview2": {
      "X": 21,
      "Y": 30,
      "ImageIndex": 8
    "Preview3": {
      "X": 21,
      "Y": 30,
      "ImageIndex": 8
  "Time": {
    "Hours": {
      "Tens": {
        "X": 3,
        "Y": 3,
        "ImageIndex": 9,
        "ImagesCount": 10
      "Ones": {
        "X": 15,
        "Y": 3,
        "ImageIndex": 9,
        "ImagesCount": 10
    "Minutes": {
      "Tens": {
        "X": 123,
        "Y": 2,
        "ImageIndex": 9,
        "ImagesCount": 10
      "Ones": {
        "X": 135,
        "Y": 2,
        "ImageIndex": 9,
        "ImagesCount": 10
    "UnknownV11": 0
  "Date": {
      "OneLine": {
        "Number": {
          "TopLeftX": 5,
          "TopLeftY": 308,
          "BottomRightX": 50,
          "BottomRightY": 324,
          "SpacingX": 1,
          "SpacingY": 0,
          "ImageIndex": 9,
          "ImagesCount": 10
        "DelimiterImageIndex": 19
      "TwoDigitsMonth": true,
      "TwoDigitsDay": true
    "ENWeekDays": {
      "X": 0,
      "Y": 20,
      "ImageIndex": 1,
      "ImagesCount": 7
  "AnalogDialFace": {
    "Hours": {
      "OnlyBorder": false,
      "Color": "0x004000",
      "Center": {
        "X": 77,
        "Y": 190
      "Shape": [
          "X": 13,
          "Y": 4
          "X": 31,
          "Y": 4
          "X": 36,
          "Y": 0
          "X": 31,
          "Y": -4
          "X": 13,
          "Y": -4
          "X": 13,
          "Y": 4
          "X": 16,
          "Y": 1
          "X": 31,
          "Y": 1
          "X": 33,
          "Y": 0
          "X": 31,
          "Y": -1
          "X": 16,
          "Y": -1
          "X": 16,
          "Y": 1
    "Minutes": {
      "Color": "0x800000",
      "Center": {
        "X": 77,
        "Y": 190
      "Shape": [
          "X": 17,
          "Y": 3
          "X": 49,
          "Y": 3
          "X": 53,
          "Y": 0
          "X": 49,
          "Y": -3
          "X": 17,
          "Y": -3
          "X": 17,
          "Y": 3
          "X": 20,
          "Y": 1
          "X": 45,
          "Y": 1
          "X": 47,
          "Y": 0
          "X": 45,
          "Y": -1
          "X": 20,
          "Y": -1
          "X": 20,
          "Y": 1
At the same time, the log does not give any errors and the program gives the message "Success".
SantiNW
Post by SantiNW »
Johnson070 wrote: 29 Mar 2021, 20:25
danyvas7 wrote: 26 Mar 2021, 22:08
Hi, i have a problem with the bin file, i save the project as bin, but the bin file is not created.
Bin file creates in directory where created json and images
No, it doesn't, it just drops the images and the .json but not the .bin
SantiNW
Post by SantiNW »
raejin wrote: 13 Jul 2021, 21:02
update: I've managed to create a .bin by using 'pallette mode' and it writes okay. The only problem is now I can't install it to my Mi Band :? Using the Notify app I get update failed, im guessing the bin is faulty somehow
I'm really at a loss as to what to do now. Dropping a link here with the files if anyone could create a .bin and/or tell me how I'd be grateful ~
https://drive.google.com/drive/folders/ ... sp=sharing
Thank you so much for the pallette mode tip
SantiNW
Post by SantiNW »
Use the pallette mode. Go to "Open settings" > Enable "Use Pallette Mode(low space)" > Click "Save" and done, you should now be able to get the .bin
user_harry
Post by user_harry »
Hey Johnson070, I am facing a problem that when adding wind or uv index the temperature goes blank, can you help me with that?
itaketapps
"Background": {
"Time": {
"Hours": {
"Tens": {
"X": 15,
"Y": 80,
"ImageIndex": 0,
"ImagesCount": 10
"Ones": {
"X": 80,
"Y": 80,
"ImageIndex": 0,
"ImagesCount": 10
"Minutes": {
"Tens": {
"X": 15,
"Y": 140,
"ImageIndex": 10,
"ImagesCount": 10
"Ones": {
"X": 80,
"Y": 140,
"ImageIndex": 10,
"ImagesCount": 10
"UnknownV11": 0
"Date": {
"OneLine": {
"Number": { !!! This line should read "Number" and not "NumberEN" !!!
"TopLeftX": 69,
"TopLeftY": 200,
"BottomRightX": 70,
"SpacingX": 1,
"SpacingY": 0,
"ImageIndex": 37,
"ImagesCount": 10
"ENWeekDays": {
"X": 15,
"Y": 200,
"ImageIndex": 48,
"ImagesCount": 7
"Battery": {
"BatteryIcon": {
"X": 0,
"Y": 0,
"ImageIndex": 20,
"ImagesCount": 7
"Other": {
"Animation": [
"X": 0,
"Y": 236,
"ImageIndex": 27,
"ImagesCount": 10
"Speed": 100,
"RepeatCount": 10,
"UnknownTF4": 1
It is necessary to correct "Number" and not "NumberEN" in the line of choosing numbers to display the date. Such a problem occurs when selecting the "OneLine" display.
xojo
Post by xojo »
itaketapps wrote: 07 Aug 2022, 22:24
  "Background": {
    "Image": {
      "X": 0,
      "Y": 0,
      "ImageIndex": 0
    "Preview1": {
      "X": 21,
      "Y": 30,
      "ImageIndex": 8
    "Preview2": {
      "X": 21,
      "Y": 30,
      "ImageIndex": 8
    "Preview3": {
      "X": 21,
      "Y": 30,
      "ImageIndex": 8
  "Time": {
    "Hours": {
      "Tens": {
        "X": 3,
        "Y": 3,
        "ImageIndex": 9,
        "ImagesCount": 10
      "Ones": {
        "X": 15,
        "Y": 3,
        "ImageIndex": 9,
        "ImagesCount": 10
    "Minutes": {
      "Tens": {
        "X": 123,
        "Y": 2,
        "ImageIndex": 9,
        "ImagesCount": 10
      "Ones": {
        "X": 135,
        "Y": 2,
        "ImageIndex": 9,
        "ImagesCount": 10
    "UnknownV11": 0
  "Date": {
      "OneLine": {
        "Number": {
          "TopLeftX": 5,
          "TopLeftY": 308,
          "BottomRightX": 50,
          "SpacingX": 1,
          "SpacingY": 0,
          "ImageIndex": 9,
          "ImagesCount": 10
    "ENWeekDays": {
      "X": 0,
      "Y": 20,
      "ImageIndex": 1,
      "ImagesCount": 7
  "AnalogDialFace": {
    "Hours": {
      "Center": {
        "X": 77,
        "Y": 190
      "Shape": [
          "X": 13,
          "Y": 4
          "X": 31,
          "Y": 4
          "X": 36,
          "Y": 0
          "X": 31,
          "Y": -4
          "X": 13,
          "Y": -4
          "X": 13,
          "Y": 4
          "X": 16,
          "Y": 1
          "X": 31,
          "Y": 1
          "X": 33,
          "Y": 0
          "X": 31,
          "Y": -1
          "X": 16,
          "Y": -1
          "X": 16,
          "Y": 1
    "Minutes": {
      "Center": {
        "X": 77,
        "Y": 190
      "Shape": [
          "X": 17,
          "Y": 3
          "X": 49,
          "Y": 3
          "X": 53,
          "Y": 0
          "X": 49,
          "Y": -3
          "X": 17,
          "Y": -3
          "X": 17,
          "Y": 3
          "X": 20,
          "Y": 1
          "X": 45,
          "Y": 1
          "X": 47,
          "Y": 0
          "X": 45,
          "Y": -1
          "X": 20,
          "Y": -1
          "X": 20,
          "Y": 1
I read this topic months ago and came back today wondering if there was a fix for this yet. I assume you've already solved this or given up on it - but when I was trying to do this months ago I concluded that the X & Y coords of the clock hands couldn't be negative numbers. Once I shifted everything to be >=0 values the hands showed up. Of course they no longer pointed accurately though.... I think the compiler doesn't process negative values in XY coords properly.
itaketapps
Thank you for your answer.
Your assumption is not entirely correct. The fact is that since writing this question I have experimented many times. In the course of my research, it turned out that the program allows negative values on the "Y" axis, but not on the "X" axis. The reason for the disappearance of the arrows is the number of points used for their construction. I have a great sample dial with 3 hands (hour, minute and second) https://amazfitwatchfaces.com/mi-band-6/view/3905 that works great with "simple" hands. Therefore, for now, I decided not to use complex shapes in the design of arrows, only triangles, quadrilaterals and pentagons.
Thanks again for your reply.
I hope that something from what I have described above will help you in creating great watch faces.
omavel
Post by omavel »
Guys, are there any forks that are not triggering virus alerts?
DiMinuto
Post by DiMinuto »
Hey there, is there a way to move the layers so the battery icon is not on top of the time?
