Russia has invaded Ukraine – the Shield of Europe. As we are protecting the World against tyranny, it’s high time to demonstrate your support of peace and democracy in Ukraine and around the world.
What’s Happening In Ukraine:
On February 24th, 2022, Russia began a full-scale invasion of ...
Se encontraron 9 coincidencias
- 18 Mar 2022, 00:53
- Jump to forum
- Jump to topic
Re: Support Ukraine 🇺🇦
Слава Украине!!!
- 18 Mar 2022, 17:46
- Jump to forum
- Jump to topic
Слава Україні! Героям слава! Смерть ворогам!
- 04 Sep 2022, 14:22
- Jump to forum
- Jump to topic
Re: Verified authors ✅
itaketapps escribió: 04 Sep 2022, 11:20Hello! I want to become part of the group of verified authors. Thank you!
- 07 Ene 2022, 14:16
- Jump to forum
- Jump to topic
- Amazfit Bip 5 ...
- Amazfit Bip 5 ...
- 19 Sep 2022, 14:59
- Jump to forum
- Jump to topic
picture creator for mi band 7
don't know, whether it is appropriate to post here.
I don't have a watchface creator, but an app, which helps on creation of the plenty images needed to create a watchface.
The app is open source and you'll find it at: https://github.com/DjangoReinhard/Watchface_ImageCreator
your feedback is ...
- 05 Mar 2023, 12:54
- Jump to forum
- Jump to topic
Re: Mi Band 5 & 6 WatchFace Editor GUI
Hey Johnson070, I am facing a problem that when adding wind or uv index the temperature goes blank, can you help me with that?
- 15 Mar 2023, 07:25
- Jump to forum
- Jump to topic
I have a problem with the analog clock. After creating the .bin file, the arrows disappear, although everything was displayed fine in the program at the time of creation. And that's not all. When I open third-party watch faces with working hands and save under a new name, they also disappear ...
- 16 Abr 2020, 14:41
- Jump to forum
- Jump to topic
Re: Anyone have a list of JSON commands
This is not my effort, I got it on the forum and it requires the MiBandWFTool1.4.2, if you want to use other tools the syntax may be a little bit different (ie. instead of "Steps->Number" it's "Steps->Step"). I added a couple of //comments and I think this file has most of the things. I only ran ...
