T-Rex Pro-Zepp Watchface Web zab-bin problem
istanbulls
- Has thanked: 1 time
I used to make watch faces with the Zepp Watchface web app and import it as a bin file to my T-rex Pro watch. The application has changed, more useful and diversified, very beautiful. but now it creates zab file instead of bin extension and I can't load it on my watch. any idea what should i do? thanks.
- Has thanked: 419 times
- Been thanked: 2108 times
Zab uses zip compress format.
You can uncompress it using winzip or winrar.
After uncompress you will find the zip file.
That ZIP file will be a compressed BIN file.
After you uncompress that zip file you will see BIN ( watchface [ source.bin ] )
istanbulls
thanks for your answer,
I already opened the zab file and tried to use the dial.bin file in it, but it fails to complete the installation. so I thought maybe I should do something else.
the watchface i made is about 1.8mb, i tried something simpler and it gave the same problem.
I even reset the watch to factory settings but it didn't work.
The watch faces I make with facemarker create a much smaller bin file. I had a problem, I added "Heart Rate Circle" is not visible on the AOD screen, maybe I shouldn't add it in the Zepp Watchface web application. I'll try like this and let you know here.
dial.bin is not watchface it's is a raw resourceistanbulls wrote: 15 Nov 2022, 08:33Spoiler
you can found zip file in zab.
After unzip that zip file you can see source.bin this file is a watchface that can sync on you watch
istanbulls
I added two watchface files. one is Facemarker (working), one is Zepp Watchface Web (not working).
maybe you can understand where is the problem thanks to these files
Thanks again for your interest...
- Attachments
- 2022Modernv4.amazfit_trex_pro_packed.bin
- Facemaker file
- (296.15 KiB) Downloaded 109 times
- dial.bin
- Zepp Watcface Web file
- (1.72 MiB) Downloaded 116 times
if you see my picture you can see in zab have 3 fileistanbulls wrote: 15 Nov 2022, 09:20I added two watchface files. one is Facemarker (working), one is Zepp Watchface Web (not working).
1. xxxxxx.zip
2. dial.bin
3. manifest.json
The issue is dial.bin is not a watchface it is raw resource so you can not sync this file to you watch
The file you can sync is in the xxxxx.zip
if you can send zab i will uncompress and send watchface back to you
istanbulls
Actually, when I have a problem, I investigate in detail, I remember looking inside that zip file and I couldn't see anythingasoo wrote: 15 Nov 2022, 08:55dial.bin is not watchface it's is a raw resourceistanbulls wrote: 15 Nov 2022, 08:33Spoiler
After unzip that zip file you can see source.bin this file is a watchface that can sync on you watchSpoiler
it's there now and works perfectly. thanks dude. It is very valuable to find someone like you who is always ready to help. thanking you is not enough for me <3
Hi can you share your app link please..(FACEMAKER and ZEPP WATCHFACE WED) thanks ahaed
