T-Rex Pro-Zepp Watchface Web zab-bin problem
istanbulls
Post by istanbulls »
I used to make watch faces with the Zepp Watchface web app and import it as a bin file to my T-rex Pro watch. The application has changed, more useful and diversified, very beautiful. but now it creates zab file instead of bin extension and I can't load it on my watch. any idea what should i do? thanks.
Has thanked: 419 times
Been thanked: 2109 times
Zab uses zip compress format.
You can uncompress it using winzip or winrar.
After uncompress you will find the zip file.
That ZIP file will be a compressed BIN file.
After you uncompress that zip file you will see BIN ( watchface [ source.bin ] )
istanbulls
thanks for your answer,
I already opened the zab file and tried to use the dial.bin file in it, but it fails to complete the installation. so I thought maybe I should do something else.
the watchface i made is about 1.8mb, i tried something simpler and it gave the same problem.
I even reset the watch to factory settings but it didn't work. :)
The watch faces I make with facemarker create a much smaller bin file. I had a problem, I added "Heart Rate Circle" is not visible on the AOD screen, maybe I shouldn't add it in the Zepp Watchface web application. I'll try like this and let you know here.
istanbulls wrote: 15 Nov 2022, 08:33
dial.bin is not watchface it's is a raw resource
you can found zip file in zab.
After unzip that zip file you can see source.bin this file is a watchface that can sync on you watch
istanbulls
I added two watchface files. one is Facemarker (working), one is Zepp Watchface Web (not working).
maybe you can understand where is the problem thanks to these files :)
Thanks again for your interest...
2022Modernv4.amazfit_trex_pro_packed.bin
Facemaker file
(296.15 KiB) Downloaded 113 times
dial.bin
Zepp Watcface Web file
(1.72 MiB) Downloaded 120 times
istanbulls wrote: 15 Nov 2022, 09:20
if you see my picture you can see in zab have 3 file
1. xxxxxx.zip
2. dial.bin
3. manifest.json
The issue is dial.bin is not a watchface it is raw resource so you can not sync this file to you watch
The file you can sync is in the xxxxx.zip
if you can send zab i will uncompress and send watchface back to you
istanbulls
asoo wrote: 15 Nov 2022, 08:55
Actually, when I have a problem, I investigate in detail, I remember looking inside that zip file and I couldn't see anything :))
it's there now and works perfectly. thanks dude. It is very valuable to find someone like you who is always ready to help. thanking you is not enough for me <3
mreps07
Post by mreps07 »
Hi can you share your app link please..(FACEMAKER and ZEPP WATCHFACE WED) thanks ahaed
