About test create GTS4 with official editor
Moderadores: asoo, Watchmens
Regras do fórum
Avatar do usuário
Has thanked: 438 times
Been thanked: 2141 times
Contato:
Mensagem por asoo »
First of all, thanks to Guydu91 for all the pictures of GTS3. used in testing GTS4 this time
https://amazfitwatchfaces.com/gts/view/9638
Today I have used Official editor and found that now the Official editor has made it possible to create a watch face of the GTS4.
So I tried to build and test it on my GTR3. The result is that it can be enabled on the GTR3 as well, but the image size is not correct because the GTS4 has screen size not same GTR3 . GTS4 screen size is same GTS3.
In my opinion, I think the GTS4 still uses the GTS3 and GTR3 dial script style.
I have attached the files that I have created in this "topic". Anyone interested can download it.
Imagem
Tested use GTS4 watchface on GTR3
Imagem
Original pack from Official editor :
TESTGTS4-1.0.1.rar
(126.72 KiB) Baixado 115 vezes
Unpack Original bring out only watchface :
GTS4.zip
(779.82 KiB) Baixado 91 vezes
I'm not sure if it works in GTS4 or not.
But expect it to work as GTS4 still uses the same zepp OS as GTS3 , GTR3.
Avatar do usuário
Guydu91
Registrado em: 06 Out 2019, 18:49
Has thanked: 59 times
Contato:
Mensagem por Guydu91 »
Hello Asoo,
If I understand your post correctly, it could mean that the GTS3 watchfaces would be directly compatible with GTS4...
I have a little doubt because the site has just integrated the download section for GTS4 Mini and... GTS4.
If compatibility existed, the GTS3 section would have become GTS3 AND GTS4.
Besides, GTS3 and GTR3 run under ZEPP OS while GTS4, GTS4 Mini and GTR3 run under ZEPP OS2.
It can change a lot of things.
Another thing: I created with Sasha's editor a watchface for GTS4 Mini.
That is to say that after a first version for GTS4 I resized it (still with the editor) because the proportions are almost identical (just the wallpaper to be rectified in height of 4 pixels).
I then submitted this dial to the validation of the online editor of the Huami site... 4 days ago, but it is still pending.
I therefore prefer to wait for this validation to post this watchface on the site.
If the validation is done by Huami, then it will verify the compatibility thesis.
FYI, I simply taken a screenshot of this page to create the watch face you just used: https://www.facer.io/watchface/RvrzCQUv ... watch4pink
Best regards.
Avatar do usuário
Contato:
Mensagem por asoo »
Guydu91 escreveu: 08 Set 2022, 12:56
Hello Asoo,
1. If I understand your post correctly, it could mean that the GTS3 watchfaces would be directly compatible with GTS4...
1. Looking from the official editor, I think the basic elements of GTS3 and GTS4 go well together.
Hello Asoo,
2. I have a little doubt because the site has just integrated the download section for GTS4 Mini and... GTS4.
2. I think GT3 and GT4 can run basic scripts all the same, but in GT4 in the future there may be more function than GT3, based on the new os installed.
3. Another thing: I created with Sasha's editor a watchface for GTS4 Mini.
3. What version of Sasha's editor did you use to create GTS4mini?
if you use 4.1 after you pack a GTS4min watchface. Your image will be encoded incorrectly.
Because Sasha told me image encoding method in GTS4min is different from GT3
viewtopic.php?p=13599#p13599
As far as know now the SashaCX75's editor Version beta can pack GTS4mini correctly
But the beta version is still in the review and testing phase.
Not yet open for download
Avatar do usuário
Registrado em: 26 Out 2019, 15:18
Been thanked: 1044 times
Contato:
Mensagem por SashaCX75 »
On the Huami website, watch faces are created for the GTS 3 and GTS 4 at the same time. One file is created for these models. Perhaps, as asoo wrote, in the future, new functions will appear on the GTS 4, which will not be on the GTS 3. Perhaps even in the official dials on the GTS 4 there are some new features. But GTS 3 should work on GTS 4. This is just my opinion, I don't have this watch and can't verify it.
Responder
Voltar para “Watchfaces creation (order table)”
Quem está online
