RZ216 convert GTR2
coolmall
RZ216 convert GTR2
Post by coolmall »
Good morning guys and have a nice week. Can anyone with knowledge help me and convert this watchface exactly the same in orange colour instead red if it's possible otherwise leave the same colour. Replace the phone with connection, the people with dnd, the temp with alarm and finally the theme with lock. Below seconds take off moon phases because GTR2 don't support and add am, pm, 24h icons up from the seconds in the empty space. Thank you so much.
coolmall
Post by coolmall »
Αnyone from creators who has knowledge if can help me i am willing to donate. Thank you.
Lattenknaller
Has thanked: 60 times
Been thanked: 132 times
Post by Lattenknaller »
I made something on the fly, but for the GTR3, but the conversion should be quick
coolmall
Post by coolmall »
Thank you so much, maybe someone now convert it for GTR2. It's perfect.
coolmall
Post by coolmall »
Hi guys, Lattenknaller give his permission to use resources from his GTR3 Pro version of watchface here https://amazfitwatchfaces.com/gtr/view/26820 Everyone with knowledge to convert it for GTR2 is welcome. Don't change nothing, it's exactly what i was want. Thank you and a big thanks to Lattenknaller for his amazing work.
Been thanked: 2092 times
coolmall wrote: 23 Aug 2022, 09:11
Fixed issue about weather icons and BT icon from Lattenknaller
viewtopic.php?p=13525#p13525
note :
coolmall
Post by coolmall »
Thank you so much, it's perfect, all works ok just one thing, can you reverse the connect to be red when is connected because it turns red when it's offline while the other 3 icons turn red when it's on and it's confusing. I'm not saying it's your fault. Thanks to Lattenknaller for the adaptation.
Sorry but i found error in weather icons, while now has cloudy night the watchface shows something else. Please if it's possible fix it and reverse connection icon became red when is connected like the rest 3 icons became red when is on. Thank you and sorry for inconvenience.
coolmall wrote: 24 Aug 2022, 08:04
If the problem is caused by the original resource, I suggest you notify to the original owner.
As far as I've checked, the weather icons is not aligned correctly. so this issue i will not fix it. I just only port from resource original.
if you want to fix please do it by yourself or notify to the original owner of the work.
coolmall
Post by coolmall »
asoo wrote: 25 Aug 2022, 02:25
Thanks a lot for the info, I'll inform Lattenknaller if he can fix it.
Lattenknaller
Try this one
RZ216_FAOD_GTR2_packed_packed.bin
(683.87 KiB) Downloaded 155 times
coolmall
Post by coolmall »
Lattenknaller wrote: 25 Aug 2022, 04:52
Try this one
Good morning and thank you for the fast response, I will try it and inform you if everything it's ok. The weather icons seems to be fixed with the connect icon. Thank you again. Please replace the old watchface with the error with the new fixed from Lattenknaller.
Lattenknaller
for GTR2:
https://amazfitwatchfaces.com/gtr/view/26898
but must first be activated by an admin
