RZ216 convert GTR2
RZ216 convert GTR2
Good morning guys and have a nice week. Can anyone with knowledge help me and convert this watchface exactly the same in orange colour instead red if it's possible otherwise leave the same colour. Replace the phone with connection, the people with dnd, the temp with alarm and finally the theme with lock. Below seconds take off moon phases because GTR2 don't support and add am, pm, 24h icons up from the seconds in the empty space. Thank you so much.
Αnyone from creators who has knowledge if can help me i am willing to donate. Thank you.
Lattenknaller
- Has thanked: 62 times
- Been thanked: 168 times
Hi guys, Lattenknaller give his permission to use resources from his GTR3 Pro version of watchface here https://amazfitwatchfaces.com/gtr/view/26820 Everyone with knowledge to convert it for GTR2 is welcome. Don't change nothing, it's exactly what i was want. Thank you and a big thanks to Lattenknaller for his amazing work.
- Has thanked: 438 times
coolmall wrote: 23 Aug 2022, 09:11Spoiler
note :
Thank you so much, it's perfect, all works ok just one thing, can you reverse the connect to be red when is connected because it turns red when it's offline while the other 3 icons turn red when it's on and it's confusing. I'm not saying it's your fault. Thanks to Lattenknaller for the adaptation.
Sorry but i found error in weather icons, while now has cloudy night the watchface shows something else. Please if it's possible fix it and reverse connection icon became red when is connected like the rest 3 icons became red when is on. Thank you and sorry for inconvenience.
If the problem is caused by the original resource, I suggest you notify to the original owner.
As far as I've checked, the weather icons is not aligned correctly. so this issue i will not fix it. I just only port from resource original.
if you want to fix please do it by yourself or notify to the original owner of the work.
Thanks a lot for the info, I'll inform Lattenknaller if he can fix it.asoo wrote: 25 Aug 2022, 02:25If the problem is caused by the original resource, I suggest you notify to the original owner.
Lattenknaller
Good morning and thank you for the fast response, I will try it and inform you if everything it's ok. The weather icons seems to be fixed with the connect icon. Thank you again. Please replace the old watchface with the error with the new fixed from Lattenknaller.
Lattenknaller
