• Administrador
G-294 (GTR3) convert for GTR2
Moderadores: asoo, Watchmens
Reglas del Foro
Responder
Avatar de Usuario
Giorgosstam
Mensaje por Giorgosstam »
Hello to forum, it would be great if someone from creators convert G-294 from asoo at red for the GTR2 without the circle for the phases of the moon and the city name and in the place of PAI put UV. Thank you very much the community and asoo for this watchface. https://amazfitwatchfaces.com/gtr/view/23474
Avatar de Usuario
alexstam78
Has thanked: 173 times
Mensaje por alexstam78 »
Yes indeed, it would be really great if someone from creators make it for GTR2 at white.
Avatar de Usuario
Has thanked: 419 times
Been thanked: 2109 times
Mensaje por asoo »
- This watchface Not test on real device , only tested on editor program
Imagen Imagen
Fixed steps number to center same as GTR3
G294_red__FAOD_GTR2.bin
(863.53 KiB) Descargado 96 veces
G294_white__FAOD_GTR2.bin
(844.41 KiB) Descargado 69 veces
G294_white__FAOD_GTR2_Change_ID.bin
(845.05 KiB) Descargado 90 veces
note :
Avatar de Usuario
alexstam78
Amazing l, thank you so much.
Avatar de Usuario
alexstam78
Sorry can you fix little the steps numbers fonts. They appear edge left. If possible put them little to the right. At GTR3 version they appear to the center.
Última edición por alexstam78 el 21 Abr 2022, 10:11, editado 1 vez en total.
Avatar de Usuario
Mensaje por asoo »
alexstam78 escribió: 20 Abr 2022, 16:14
Sorry can you fix little the steps numbers fonts. Thy appear edge left. If possible put them little to the right. At GTR3 version they appear to the center.
viewtopic.php?p=12586#p12586
Avatar de Usuario
alexstam78
Thank you, fixed.
Avatar de Usuario
Giorgosstam
Wow, thanks from Italy. If i install white version and install red version the one replace the other. You can't have the 2 version together.
Avatar de Usuario
Mensaje por asoo »
Giorgosstam escribió: 21 Abr 2022, 04:04
your request is only red .So I didn't change ID in white
But you can do it by yourself by use program editor open file bin and change ID.
This time I will do it for you. But the next time please try it by yourself
Avatar de Usuario
Giorgosstam
Thank you.
SleepyHollow
Has thanked: 24 times
Contactar:
Mensaje por SleepyHollow »
Hello guys, is it possible someone who have skills and knowledge make a version of white watchface without the analog hands. Only take off analog hands and change id to can have the analog and the digital version of this wonderful watchface. Thank you guys and have a nice day.
Responder
¿Quién está conectado?
