G-294 (GTR3) convert for GTR2
Giorgosstam
Post by Giorgosstam »
Hello to forum, it would be great if someone from creators convert G-294 from asoo at red for the GTR2 without the circle for the phases of the moon and the city name and in the place of PAI put UV. Thank you very much the community and asoo for this watchface. https://amazfitwatchfaces.com/gtr/view/23474
alexstam78
Has thanked: 173 times
Post by alexstam78 »
Yes indeed, it would be really great if someone from creators make it for GTR2 at white.
Has thanked: 441 times
Been thanked: 2142 times
- This watchface Not test on real device , only tested on editor program
Image Image
Fixed steps number to center same as GTR3
G294_red__FAOD_GTR2.bin
(863.53 KiB) Downloaded 97 times
G294_white__FAOD_GTR2.bin
(844.41 KiB) Downloaded 70 times
G294_white__FAOD_GTR2_Change_ID.bin
(845.05 KiB) Downloaded 91 times
note :
alexstam78
Amazing l, thank you so much.
alexstam78
Sorry can you fix little the steps numbers fonts. They appear edge left. If possible put them little to the right. At GTR3 version they appear to the center.
alexstam78 wrote: 20 Apr 2022, 16:14
Sorry can you fix little the steps numbers fonts. Thy appear edge left. If possible put them little to the right. At GTR3 version they appear to the center.
viewtopic.php?p=12586#p12586
alexstam78
Thank you, fixed.
Giorgosstam
Wow, thanks from Italy. If i install white version and install red version the one replace the other. You can't have the 2 version together.
Giorgosstam wrote: 21 Apr 2022, 04:04
your request is only red .So I didn't change ID in white
But you can do it by yourself by use program editor open file bin and change ID.
This time I will do it for you. But the next time please try it by yourself
Giorgosstam
Thank you.
SleepyHollow
Has thanked: 30 times
Post by SleepyHollow »
Hello guys, is it possible someone who have skills and knowledge make a version of white watchface without the analog hands. Only take off analog hands and change id to can have the analog and the digital version of this wonderful watchface. Thank you guys and have a nice day.
