G-294 (GTR3) convert for GTR2
- Giorgosstam
Hello to forum, it would be great if someone from creators convert G-294 from asoo at red for the GTR2 without the circle for the phases of the moon and the city name and in the place of PAI put UV. Thank you very much the community and asoo for this watchface. https://amazfitwatchfaces.com/gtr/view/23474
- alexstam78
- Has thanked: 173 times
Yes indeed, it would be really great if someone from creators make it for GTR2 at white.
- Has thanked: 441 times
- This watchface Not test on real device , only tested on editor program
Fixed steps number to center same as GTR3 note :
- alexstam78
- alexstam78
Sorry can you fix little the steps numbers fonts. They appear edge left. If possible put them little to the right. At GTR3 version they appear to the center.
Fixed steps number to center same as GTR3alexstam78 wrote: 20 Apr 2022, 16:14Sorry can you fix little the steps numbers fonts. Thy appear edge left. If possible put them little to the right. At GTR3 version they appear to the center.
viewtopic.php?p=12586#p12586
- alexstam78
- Giorgosstam
Wow, thanks from Italy. If i install white version and install red version the one replace the other. You can't have the 2 version together.
your request is only red .So I didn't change ID in whiteGiorgosstam wrote: 21 Apr 2022, 04:04Wow, thanks from Italy. If i install white version and install red version the one replace the other. You can't have the 2 version together.
But you can do it by yourself by use program editor open file bin and change ID.
This time I will do it for you. But the next time please try it by yourself
- Giorgosstam
SleepyHollow
- Has thanked: 30 times
- Been thanked: 2 times
Hello guys, is it possible someone who have skills and knowledge make a version of white watchface without the analog hands. Only take off analog hands and change id to can have the analog and the digital version of this wonderful watchface. Thank you guys and have a nice day.
