Please Help! Jeweler Basic Hybrid GTR2
alexstam78
Has thanked: 173 times
Post by alexstam78 »
Hello to community and to creators, can anyone from creators port this amazing watchface exactly the same gray
yellow like pictures for GTR2. If it is possible because GTR2 does not support phases of the moon add 24h, pm, am within the perimeter of the digital time unless you have a better idea of ​​how to use the circle of moon phases and add weather. Unfortunately I don't have the ability and the skills to do it myself so I ask for help from here. Thanks to all creators . Thanks for hospitality.
kotobuki09
Post by kotobuki09 »
It's would be great if someone can make the GTR3 Pro version as well!! Thanks
alexstam78
kotobuki09 wrote: 31 Mar 2022, 15:03
Yes, friend, it's would be great if someone make it for both GTR2 and GTR3.
alexstam78
You are lucky, already made for GTR3 pro here
https://amazfitwatchfaces.com/gtr/view/23083
Has thanked: 437 times
Been thanked: 2141 times
J-Basic_FAOD_GTR2_Fix_dot_dis.bin
(948.68 KiB) Downloaded 110 times
alexstam78
Amazing, thank you, asoo, works ok.
Has thanked: 205 times
Post by amazfitfacesafrica »
asoo wrote: 03 Apr 2022, 11:34
J-Basic_FAOD_GTR2_packed.bin
Hello, is it possible someone who has knowledge fix distance dot at numbers don't appear. Thank you.
amazfitfacesafrica wrote: 07 Jun 2022, 11:18
Fixed :
viewtopic.php?p=12468#p12468
Thank you for the fix.
