Please Help! Jeweler Basic Hybrid GTR2
- alexstam78
- Has thanked: 173 times
Hello to community and to creators, can anyone from creators port this amazing watchface exactly the same gray
yellow like pictures for GTR2. If it is possible because GTR2 does not support phases of the moon add 24h, pm, am within the perimeter of the digital time unless you have a better idea of how to use the circle of moon phases and add weather. Unfortunately I don't have the ability and the skills to do it myself so I ask for help from here. Thanks to all creators . Thanks for hospitality.
kotobuki09
- Has thanked: 13 times
- Been thanked: 2 times
It's would be great if someone can make the GTR3 Pro version as well!! Thanks
- alexstam78
Yes, friend, it's would be great if someone make it for both GTR2 and GTR3.kotobuki09 wrote: 31 Mar 2022, 15:03It's would be great if someone can make the GTR3 Pro version as well!! Thanks
- alexstam78
You are lucky, already made for GTR3 pro herekotobuki09 wrote: 31 Mar 2022, 15:03It's would be great if someone can make the GTR3 Pro version as well!! Thanks
https://amazfitwatchfaces.com/gtr/view/23083
- Has thanked: 417 times
- Been thanked: 2088 times
Please read carefully before download.- use images as far as can be used from image from original watchface
- alexstam78
- Has thanked: 205 times
- Been thanked: 5 times
asoo wrote: 03 Apr 2022, 11:34
J-Basic_FAOD_GTR2_packed.bin
amazfitfacesafrica wrote: 07 Jun 2022, 11:18Hello, is it possible someone who has knowledge fix distance dot at numbers don't appear. Thank you.
viewtopic.php?p=12468#p12468
Thank you for the fix.
