JEWELER TACTICAL for GTR2
- alexstam78
- Has thanked: 173 times
Hello to community and to creators, can anyone from creators port this amazing watchface exactly the same for GTR2. Unfortunately I don't have the ability and the skills to do it myself so I ask for help from here. Thanks to all creators . Thanks for hospitality. https://galaxystore.samsung.com/geardet ... erTactical
- Has thanked: 409 times
- Been thanked: 2037 times
Please read carefully before download.- use images as far as can be used from image from original watchface
- alexstam78
Thank you, asoo professor of adaptation. Much appreciated. I test it but the digital time don't work well, I use 24h and the dnd icon must put somewhere else or take off completely. You can see digital time in preview. Digital time don't have the 0 in front of numbers of hours. The am, pm .12 icon if you choose 24h must change and be am, pm, 24 instead of 12. Please fix 24h and digital time and take off completely DND icon or put it somewhere else. Thank you.
Fixedalexstam78 wrote: 23 Mar 2022, 07:44Thank you, asoo professor of adaptation. Much appreciated. I test it but the digital time don't work well, I use 24h and the dnd icon must put somewhere else or take off completely. You can see digital time in preview. Digital time don't have the 0 in front of numbers of hours. The am, pm .12 icon if you choose 24h must change and be am, pm, 24 instead of 12. Please fix 24h and digital time and take off completely DND icon or put it somewhere else. Thank you.
viewtopic.php?p=12364#p12364
- alexstam78
Thank you, asoo, digital time fixed and 24h fixed.asoo wrote: 23 Mar 2022, 08:13Fixedalexstam78 wrote: 23 Mar 2022, 07:44Thank you, asoo professor of adaptation. Much appreciated. I test it but the digital time don't work well, I use 24h and the dnd icon must put somewhere else or take off completely. You can see digital time in preview. Digital time don't have the 0 in front of numbers of hours. The am, pm .12 icon if you choose 24h must change and be am, pm, 24 instead of 12. Please fix 24h and digital time and take off completely DND icon or put it somewhere else. Thank you.
- alexstam78
Sorry, asoo, is it possible in version without DND icon to put Bluetooth icon in the circle of moon? Because there is more visible for me and fit better since GTR2 does not support the phases of the Moon. Thank you.asoo wrote: 23 Mar 2022, 08:13Fixedalexstam78 wrote: 23 Mar 2022, 07:44Thank you, asoo professor of adaptation. Much appreciated. I test it but the digital time don't work well, I use 24h and the dnd icon must put somewhere else or take off completely. You can see digital time in preview. Digital time don't have the 0 in front of numbers of hours. The am, pm .12 icon if you choose 24h must change and be am, pm, 24 instead of 12. Please fix 24h and digital time and take off completely DND icon or put it somewhere else. Thank you.
Sorry i will not do it.alexstam78 wrote: 30 Mar 2022, 08:49Sorry, asoo, is it possible in version without DND icon to put Bluetooth icon in the circle of moon? Because there is more visible for me and fit better since GTR2 does not support the phases of the Moon. Thank you.
If it's a request to correct what I've done wrong, I'll do it.
As I have already said in the post
I would like to express my personal opinion.
Why don't you try edit by yourself What you ask to modify is not difficult at all. You have a finished manuscript. Just spend a little time with it, I think you should be able to do it.
I think the first attempt might not succeed but if you try I think you can. If you try. I think human can do anything that he can think .
- alexstam78
Believe me if i had the ability to do it i would do it and secondanly i don't have windows pc, only android tablet and phone and if i am right you need windows pc to do this. Thank you anyway.
