JEWELER TACTICAL for GTR2
alexstam78
Has thanked: 173 times
Post by alexstam78 »
Hello to community and to creators, can anyone from creators port this amazing watchface exactly the same for GTR2. Unfortunately I don't have the ability and the skills to do it myself so I ask for help from here. Thanks to all creators . Thanks for hospitality. https://galaxystore.samsung.com/geardet ... erTactical
Has thanked: 441 times
Been thanked: 2142 times
J-Tactical_FAOD_GTR2_Fix_hour_2digi_packed.bin
(909.38 KiB) Downloaded 41 times
alexstam78
Thank you, asoo professor of adaptation. Much appreciated. I test it but the digital time don't work well, I use 24h and the dnd icon must put somewhere else or take off completely. You can see digital time in preview. Digital time don't have the 0 in front of numbers of hours. The am, pm .12 icon if you choose 24h must change and be am, pm, 24 instead of 12. Please fix 24h and digital time and take off completely DND icon or put it somewhere else. Thank you.
alexstam78 wrote: 23 Mar 2022, 07:44
Fixed
viewtopic.php?p=12364#p12364
alexstam78
asoo wrote: 23 Mar 2022, 08:13
Fixed
Thank you, asoo, digital time fixed and 24h fixed.
alexstam78
Fixed
Sorry, asoo, is it possible in version without DND icon to put Bluetooth icon in the circle of moon? Because there is more visible for me and fit better since GTR2 does not support the phases of the Moon. Thank you.
alexstam78 wrote: 30 Mar 2022, 08:49
Sorry i will not do it.
If it's a request to correct what I've done wrong, I'll do it.
As I have already said in the post
I would like to express my personal opinion.
Why don't you try edit by yourself What you ask to modify is not difficult at all. You have a finished manuscript. Just spend a little time with it, I think you should be able to do it.
I think the first attempt might not succeed but if you try I think you can. If you try. I think human can do anything that he can think .
alexstam78
Believe me if i had the ability to do it i would do it and secondanly i don't have windows pc, only android tablet and phone and if i am right you need windows pc to do this. Thank you anyway.
