JEWELER TARGET HYBRID for GTR2
alexstam78
Has thanked: 173 times
Post by alexstam78 »
Hello to community and to creators, can anyone from creators port this amazing watchface exactly the same for GTR2. If it is possible add bluetooth icon in the circle of moon phases because GTR2 don't support it. Unfortunately I don't have the ability and the skills to do it myself so I ask for help from here. Thanks to all creators . Thanks for hospitality.
https://galaxystore.samsung.com/geardet ... bridYellow
Has thanked: 437 times
Been thanked: 2141 times
Image Image
JEWELER_TARGET_HYBRID_FAOD_GTR2.bin
(1.15 MiB) Downloaded 66 times
JEWELER_TARGET_HYBRID_RED_FAOD_GTR2_New_ID.bin
(1.05 MiB) Downloaded 84 times
alexstam78
Thank you, asoo, amazing you add 2 colour, much appreciated.
alexstam78
Sorry asoo, can you fix the id because you can not have both colors together. Thank you.
alexstam78 wrote: 26 Mar 2022, 08:25
viewtopic.php?p=12394#p12394
Changed ID in Red Version
alexstam78
asoo wrote: 26 Mar 2022, 09:22
Thank you.
