JEWELER TARGET HYBRID for GTR2
- alexstam78
- Has thanked: 173 times
Hello to community and to creators, can anyone from creators port this amazing watchface exactly the same for GTR2. If it is possible add bluetooth icon in the circle of moon phases because GTR2 don't support it. Unfortunately I don't have the ability and the skills to do it myself so I ask for help from here. Thanks to all creators . Thanks for hospitality.
https://galaxystore.samsung.com/geardet ... bridYellow
- Has thanked: 437 times
- Been thanked: 2141 times
Please read carefully before download.- use images as far as can be used from image from original watchface
- alexstam78
- alexstam78
Sorry asoo, can you fix the id because you can not have both colors together. Thank you.
viewtopic.php?p=12394#p12394alexstam78 wrote: 26 Mar 2022, 08:25Sorry asoo, can you fix the id because you can not have both colors together. Thank you.
Changed ID in Red Version
- alexstam78
Thank you.asoo wrote: 26 Mar 2022, 09:22viewtopic.php?p=12394#p12394alexstam78 wrote: 26 Mar 2022, 08:25Sorry asoo, can you fix the id because you can not have both colors together. Thank you.
