- Amministratore
Need Help AVl-8 Hawker Harrier ll rotor for GTR2
- alexstam78
- Has thanked: 173 times
Hello to community and to creators, can anyone from creators port this amazing watchaface from kartoris82 exactly the same for GTR2. Unfortunately I don't have the ability and the skills to do it myself so I ask for help from here. Thanks to all creators and to community for hospitality and especially to asoo for the support and for his works .
https://amazfitwatchfaces.com/gtr/view/20802
- Has thanked: 415 times
- Been thanked: 2083 times
Thank kartoris82 for original port this watchface in GTR3
This dial is interesting.
I've ported, but had to modify the layout a bit so it could be rendered close to the original.
Fix issue Preview screen not found Note : Not test on real device
- alexstam78
Αbsolutely no problem, and only you did it is enough you did it, it's just fine and thank you very much. Thanks kartoris82 and asoo for this lovely watchface.
- alexstam78
Works perfect, I test it, one thing is that no have preview to select it when change with other, it's completely black.
Fixed Please download againalexstam78 ha scritto: 17 gen 2022, 15:32Works perfect, I test it, one thing is that no have preview to select it when change with other, it's completely black.
viewtopic.php?p=11812#p11812
- alexstam78
- alexstam78
Sorry, one last thing, can you add digital time above day with small numbers? If you haven't enough space take off day. To help find time quickly. Thank you again so much.
I can do like this :
- Fixed Digital min. not show
- Fixed Digital min. not show in AOD End for this request
- alexstam78
Wow, you are in n my mind, perfect. Excellent, thank you so much.
- alexstam78
Digital hour appear, digital minutes don't. If is possible take out the 2 dots between the hour and the minute, if it doesn't leave it as it is. Thank you again so much.
??? "digital minutes don't" , I don't understand what you mean , and i can not test on real device. Because I don't have it . I tested on editor Digital hour and minutes show normal same the picture preview , if on the real device minutes it's not show I also don't know how to fix it. but I will check italexstam78 ha scritto: 18 gen 2022, 15:34Digital hour appear, digital minutes don't. If is possible take out the 2 dots between the hour and the minute, if it doesn't leave it as it is. Thank you again so much.
Version delete dot uploaded
viewtopic.php?p=11823#p11823
- alexstam78
I mean digital minutes don't appear like in preview, only digital hour number. Thank you for trying, much appreciated.
Fixed digital min. not show. Any results, please report back.alexstam78 ha scritto: 18 gen 2022, 18:13I mean digital minutes don't appear like in preview, only digital hour number. Thank you for trying, much appreciated.
- alexstam78
Yes now works perfect minutes appear. Thank you very much for the fix.asoo ha scritto: 18 gen 2022, 18:22try to fix digital min. not show. Any results, please report back.alexstam78 ha scritto: 18 gen 2022, 18:13I mean digital minutes don't appear like in preview, only digital hour number. Thank you for trying, much appreciated.
Fixed Please download againalik7676 ha scritto: 19 gen 2022, 06:15in full aod digital minutes don't appear like in preview
Visitano il forum: Amazon [Bot] e 1 ospite
