Need Help AVl-8 Hawker Harrier ll rotor for GTR2
alexstam78
Has thanked: 173 times
Post by alexstam78 »
Hello to community and to creators, can anyone from creators port this amazing watchaface from kartoris82 exactly the same for GTR2. Unfortunately I don't have the ability and the skills to do it myself so I ask for help from here. Thanks to all creators and to community for hospitality and especially to asoo for the support and for his works .
https://amazfitwatchfaces.com/gtr/view/20802
Has thanked: 438 times
Been thanked: 2142 times
Thank kartoris82 for original port this watchface in GTR3
This dial is interesting.
I've ported, but had to modify the layout a bit so it could be rendered close to the original.
Fix issue Preview screen not found
hh2rotor_gtr2__eng.bin
(761.59 KiB) Downloaded 123 times
Note : Not test on real device
alexstam78
Αbsolutely no problem, and only you did it is enough you did it, it's just fine and thank you very much. Thanks kartoris82 and asoo for this lovely watchface.
alexstam78
Works perfect, I test it, one thing is that no have preview to select it when change with other, it's completely black.
alexstam78 wrote: 17 Jan 2022, 15:32
Fixed Please download again
viewtopic.php?p=11812#p11812
alexstam78
Thank you very much.
alexstam78
Sorry, one last thing, can you add digital time above day with small numbers? If you haven't enough space take off day. To help find time quickly. Thank you again so much.
I can do like this :
- Fixed Digital min. not show
- Fixed Digital min. not show in AOD
HH2_v4_nodot_GTR2.bin
(737.57 KiB) Downloaded 135 times
End for this request
alexstam78
Wow, you are in n my mind, perfect. Excellent, thank you so much.
alexstam78
Digital hour appear, digital minutes don't. If is possible take out the 2 dots between the hour and the minute, if it doesn't leave it as it is. Thank you again so much.
alexstam78 wrote: 18 Jan 2022, 15:34
??? "digital minutes don't" , I don't understand what you mean , and i can not test on real device. Because I don't have it . I tested on editor Digital hour and minutes show normal same the picture preview , if on the real device minutes it's not show I also don't know how to fix it. but I will check it
Version delete dot uploaded
viewtopic.php?p=11823#p11823
alexstam78
I mean digital minutes don't appear like in preview, only digital hour number. Thank you for trying, much appreciated.
alexstam78 wrote: 18 Jan 2022, 18:13
Fixed digital min. not show. Any results, please report back.
alexstam78
asoo wrote: 18 Jan 2022, 18:22
try to fix digital min. not show. Any results, please report back.
Yes now works perfect minutes appear. Thank you very much for the fix.
alik7676
Has thanked: 24 times
Post by alik7676 »
in full aod digital minutes don't appear like in preview
alik7676 wrote: 19 Jan 2022, 06:15
alik7676
Post by alik7676 »
Thank you very much
