• Administrador
Regras do fórum
Avatar do usuário
Registrado em: 26 Out 2019, 15:18
Contato:
Mensagem por SashaCX75 »
Editado pela última vez por SashaCX75 em 17 Jun 2026, 20:16, em um total de 53 vezes.
Avatar do usuário
Contato:
JACKpark
I don't understand what you mean by "random location AOD".
The position of all elements is specified by specific coordinates. The image on the AOD screen is shifted by a few pixels in a random order about once a minute, this is determined by the watch firmware.
You can write code that will change the coordinates of the elements in random order. The firmware of the watch allows you to do this. But writing code is a more complex process and in the editor this will not be possible.
Avatar do usuário
Contato:
FeRu
I was unable to use the .tff file with the font in the watch face and I have not seen such watch faces. It is possible to display data in embedded font, but it is problematic. In addition, unlike GTR2, the system font cannot be rotated or written in a circle (I do not know about such possibilities). Therefore, I see no benefit from using the system font.
Avatar do usuário
FeRu
Registrado em: 06 Mai 2021, 11:46
Has thanked: 14 times
Been thanked: 8 times
Contato:
Mensagem por FeRu »
SashaCX75 escreveu: 13 Jan 2022, 15:13
@FeRu
Ok I see ;) . Thanks for info. I think about that because I liked this feature with GTR2 and sometimes i thiked that It could be much better to change that system font to other style...but we can live without this :lol:
Anyway can't wait for next relase :twisted: Keep up great work
And one more question about animation features. GTR3 support .gif animations? Or it will be standard set of png images with option to adjust speed in editor.
Avatar do usuário
Contato:
FeRu
GIF files are not supported. You can make animation using a set of images. It is possible to make an animation by moving along given coordinates, as it was in GTR 1, but I'm not sure about that.
rondolfo
Registrado em: 23 Nov 2021, 15:02
Contato:
Mensagem por rondolfo »
This looks great - thanks for your hard work Sasha! I can see how to create a dial and export it as a zip.
But how do I get it on to my watch - a GTR3 Pro?
As a test, I've taken a basic face, changed the background on it, and now I'd like to upload it to the watch.
Apparently this involves overwriting .bin files in com.huami.etc data folders (with what - the .zip file created by the app?!), or pressing the upload button next to the download button in the app and then uploading (or downloading, or perhaps both simultaneously :D ) some files to somewhere but not the preview file because you can't change that and you can forget it all anyway if you have a phone with Android 11+ on it.
Sorry, I've spent many hours searching but I can't make head nor tale of it! Any clues anyone?
Dema
Registrado em: 04 Jul 2019, 20:48
Contato:
Mensagem por Dema »
SashaCX75 , I'm sorry to disturb you again, but I'm facing a strange bug and i can't figure out what is happening..
I'm building a GTS 3 Watchface and everything seems to be ok until i upload my dial on the Watch.
On the tool everything is ok, also the preview generated is ok, but when I put the dial on the Watch, the image that I have use for the "1" of the hours results more larger than what it is, not the number itself, but the empty space around it. I have tried to modify it but show ever a lot of empty space around it.
Can you figure out what's going on?
Can i send my work to you to take a look?
jerrywm2
Registrado em: 13 Jan 2022, 15:05
Contato:
Mensagem por jerrywm2 »
Thank you so much @SashaCX75. I know this should be simple, but can anyone tell me how I actually install the .zip file on my watch after I pack it? Thank you!
Dema
Contato:
Mensagem por Dema »
jerrywm2 escreveu: 14 Jan 2022, 01:21
The simplest way is using amacfaces android app.
You can upload your dials creating a private page on amazfitwatchfaces, then you put this page in your favourites and through the app you can install it really easily.
Mazaias
Registrado em: 05 Jul 2020, 19:11
Contato:
Mensagem por Mazaias »
Dema escreveu: 14 Jan 2022, 08:45
Mazaias
Contato:
Dema
Contato:
Mensagem por Dema »
Mazaias escreveu: 14 Jan 2022, 11:25
Thank you very much! I did not know this method! :roll:
rondolfo
Contato:
Aha, this sounds like we might be getting somewhere! Thanks for your reply Dema, can I please get some help from you?
I logged in to my account here.
I clicked on Upload, filled in the form and uploaded my test dial (test1.zip).
The link to make it private doesn't seem to work - it says "You do not have any uploaded watch saces" and just takes me to a seemingly unrelated page.
So I've uploaded a dial which has disappeared and which I can't make private. :(
rondolfo
Contato:
Thanks Mazalas. On my phone (Android 11) I don't get the option to 'open' the bin with the Amazfaces app.
On an older phone I do get the option but when I try to install, it fails. This is trying it with a working file I just downloaded from this site and haven't modified in any way other than to change the file extension to .bin.
When I try to install the app says "Checking File ...xxx.zip" -- note it says 'zip' there, even though the file is .bin - so that's weird - then when I click 'Go to Installation' I get the failure message "Wrong format the file".
So - doesn't work. Any clues about what I might be doing wrong?
Thanks for looking!
Mazaias
Contato:
rondolfo escreveu: 14 Jan 2022, 13:38
Thanks for looking!
Install a third-party file browser. In my case, I use MixExplorer but anyone should do. With this you can now open the bin with amazfaces.
Why do you get the error on the other mobile? It would have to be studied carefully.
Dema
Contato:
Mensagem por Dema »
Thanks for looking!
Anyway, in your account there is "my upload" section, you find your page there, if you can't find it, if you try to do another private page, considering that can be only a private page for each user, the page show you a link to your other page.. I hope is clear, my English is awful.. :lol:
See the attached photo for example
Imagem
Dema
Contato:
Mensagem por Dema »
rondolfo escreveu: 14 Jan 2022, 13:25
Furthermore, to share your page, the simple URL is enough... Copy that from your browser and share that ;)
Avatar do usuário
Contato:
Personally, I prefer to use this program to install the created watch faces on the GTR 3 (for the GTS 3)
Avatar do usuário
Contato:
Dema escreveu: 14 Jan 2022, 00:03
Yes, you can send your work. Only it is better to send not a finished dial, but the original project. If the error is not very noticeable, then it is better to somehow indicate in the photo or preview the place you need to pay attention to.
Dema
Contato:
Mensagem por Dema »
SashaCX75 escreveu: 14 Jan 2022, 15:33
I tried to modify each number of my incriminate dial, to give each number the same X/Y dimensions, and that fixed partially the situation. The empty space around numbers doesn't look larger anymore, but i notice that the preview isn't exactly the same that the final result and I can't understand why, some numbers appears a bit decentred, it feels a bit strange.... my other dials doesn't have that problem.
I can send you a zip containing the json and the assets ok? I send you in private. Thank you
rondolfo
Contato:
Yeah, like that'll make any difference... :? HOLY F**K, thank you so much Mazaias! I opened CX Explorer, (already installed) and it let me select file type 'Other' then allowed me to associate pretty much any app at all with the .bin. Which then opened perfectly in the Amazfaces app then installed straight on to the watch. Just to check, I did the same on the old phone and this time it didn't choke on the 'invalid file' error, nor 'recognise' it as a .zip, so that appears to have been some kind of bizarre error related to the stock file explorer. So the moral of the story is: use a third party browser, not the one that came with your phone. Because reasons :lol: .
For some reason the thumbnail on my watch is a number '3' but I can live with that for now.
Brilliant, I am finally on my way to making my first watchface. That's this weekend sorted... Thanks everybody! :D
rondolfo
Contato:
SashaCX75 escreveu: 14 Jan 2022, 15:29
Excellent, thanks. I find it strange that it kinda overwrites the 'Get Moving' dial in the Zepp app in order to install its dials but it seems you can do this over and over again and nothing breaks...! And it installs the correct preview thumbnail too so all in all it works very well.
I'm looking forward to using your Watch Face Editor app this weekend!
rondolfo
Contato:
Dema escreveu: 14 Jan 2022, 15:11
Thanks Dema. I'll try it again when I have something useful to upload to the site :D . The other methods of transfer seem more efficient anyway.
Mazaias
Contato:
rondolfo escreveu: 14 Jan 2022, 15:45
I'm glad I helped.
As for the thumbnail of the number 3 I imagine it will be the preview. Select the correct image in "preview" within the "background" option.
Imagem
gengtrex
Registrado em: 06 Fev 2021, 02:47
Contato:
Mensagem por gengtrex »
hi sasha. SashaCX75
just a quick question.
thanks a lot in advance.
Avatar do usuário
FeRu
Contato:
Mensagem por FeRu »
gengtrex escreveu: 16 Jan 2022, 08:07
hi sasha. @SashaCX75
Responder
Quem está online
Usuários navegando neste fórum: Nenhum usuário registrado e 8 visitantes
