欢迎大家交流、提交 zepp OS 相关经验、问题,可以得官方第一时间的回复。
willo83417
willo83417
華米的線上錶盤工具,實際測試還有溫度"负号图片",溫度"單位圖片" 則是無法顯示
手錶:Amazfit Bip U
seethebridges
- Has thanked: 1 time
Good evening. I am an english native speaker, but I will try and use google translate here as well for convenience sake. Im trying to use the huami watchface maker for the GT2. When i go to export however, I get an error that reads: "encoder script file not exists". Is this an error on Huami's side? Or do I need to do something else in order to be able to export watchfaces for the GTS2?
Translate:
晚上好。 我是英语母语人士,但为了方便起见,我也会在这里尝试使用谷歌翻译。 我正在尝试为 GT2 使用 huami 表盘制造商。 但是,当我去导出时,我收到一条错误消息:“编码器脚本文件不存在”。 这是华米这边的失误吗? 还是我需要做其他事情才能为 GTS2 导出表盘?
Thank you for your time!
Translate:
- TXK
- Has thanked: 149 times
- Been thanked: 97 times
2022-01-14:seethebridges wrote: 12 Jan 2022, 01:26Good evening. I am an english native speaker, but I will try and use google translate here as well for convenience sake. Im trying to use the huami watchface maker for the GT2. When i go to export however, I get an error that reads: "encoder script file not exists". Is this an error on Huami's side? Or do I need to do something else in order to be able to export watchfaces for the GTS2?
Translate:
官方回复,已经修复好了,请您测试一下是否可以正常使用了?
Official reply, it has been repaired. Please test whether it can be used normally?
seethebridges
It appears to be fixed. Watch faces will now export in Zip format. Thank you!TXK wrote: 13 Jan 2022, 12:272022-01-14:
它似乎已修复。 表盘现在将以 Zip 格式导出。 谢谢!
paulkva
- Has thanked: 2 times
我也看到了同样的错位问题,所有单位都出现在左上角。 我还看到了透明度问题,即热区和其他元素会阻挡其他元素,即使它们以前是透明的。 有什么建议? 我试过清除缓存、cookie 和本地存储。 谢谢! 另外,我对任何翻译问题表示歉意,因为我不懂中文。willo83417 wrote: 29 Dec 2021, 14:01華米的線上錶盤工具,實際測試還有溫度"负号图片",溫度"單位圖片" 則是無法顯示
手錶:Amazfit Bip U
所附图片来自 https://amazfitwatchfaces.com/gts/view/6353 的编辑器
I'm seeing the same misalignment problem as well, where all units appear on the top left. I'm also seeing a problem with transparency, where hot zones and other elements block others, even though they were previously transparent. Any suggestions? I've tried clearing cache, cookies, and local storage. Thanks! Also, my apologies for any translation issues as I do not know Chinese.
The attached image is from the editor for https://amazfitwatchfaces.com/gts/view/6353
- TXK
paulkva wrote: 16 Jan 2022, 00:06
手錶:Amazfit Bip U
I have fed back your question to the official
I can read English.
Thank you for your translation.
paulkva
谢谢你。 我想既然这个帖子主要是中文的,而且我看到其他人提供两种语言,我也会这样做。 如果你同意我只用英语回复,我会的。
Thank you. I figured since this thread is primarily Chinese and I saw someone else provide both languages, I would do so as well. If you're OK with me replying in only English, I will.
- TXK
您提交的问题已经修复,请刷新浏览器缓存、重启。然后测试一下。paulkva wrote: 21 Jan 2022, 01:27就其价值而言,单位定位现在似乎已修复,但我仍然看到透明度问题。
For what it's worth, the unit positioning seems to be fixed now, but I'm still seeing transparency issues.
(关于透明背景还是会遮挡其他元素的问题,我已再次提交给官方)
The problem you submitted has been fixed. Please refresh the browser cache and restart. Then test it.
(I have submitted it to the official again about whether the transparent background will block other elements)
- TXK
Can you upload some pictures of the dial when it goes wrong?paulkva wrote: 22 Jan 2022, 04:46谢谢你的帮助。 即使在清除缓存并重新启动浏览器后,透明度问题仍然存在。
Thanks for your help. The transparency issue remains even after clearing my cache and restarting my browser.
paulkva
I already did - please see my message above from January 15.
This is a link to a working version of the watch face:
On the left is what I expect, and on the right is what it looks like today on the official editor -- still the same as it was on the 15th, except the units are once again in the correct position:
Thanks again for your help!
