G284 (GTR3) asoo for GTR2
Moderadores: asoo, Watchmens
Reglas del Foro
Responder
Avatar de Usuario
alexstam78
Has thanked: 173 times
Mensaje por alexstam78 »
Hello to community, can anyone from creators port this amazing watchaface exactly the same, only change PAI with pulse for GTR2? I post this because asoo stop make watchfaces for GTR2. Thank you very much to all creators and to asoo for his work.
https://amazfitwatchfaces.com/gtr/view/19920
alik7676
Has thanked: 24 times
Contactar:
Mensaje por alik7676 »
I join the request
Avatar de Usuario
Has thanked: 441 times
Been thanked: 2142 times
Contactar:
Mensaje por asoo »
OK, probably no one does.
Let's just say, I will made it, but it might not be tested on a real device.
If the watch face there are any issue or want to change something , I ask that , please try to fix or modify it by yourself.
Imagen
G284aGTR2.bin
(1.24 MiB) Descargado 60 veces
Avatar de Usuario
alexstam78
Thank you so much, asoo, I test it, everything works fine. Thank you again, Merry Christmas and happy New year.
Avatar de Usuario
alexstam78
I find one error, i have 39% battery and watchaface shows 50, please fix it because i don't have the skills to do it, thank you so much.
Avatar de Usuario
Contactar:
Mensaje por asoo »
alexstam78 escribió: 17 Dic 2021, 07:25
May be happened but i am not sure I can not test because i do not have it.
Because using 10 images to show the approximate battery values as follows
This is an approximate value, it may be higher or lower. -+3-5%
1-10 = 10% 51-60 = 60%
11-20 = 20% 61-70 = 70%
21-30 = 30% 71-80 = 80%
31-40 = 40% 81-90 = 90%
41-50 = 50% 91-100 = 100%
I have already stated in the description.
Avatar de Usuario
alexstam78
Yes of course i see the description that's why I say this, because according to your description of the battery rates since I have a 39% battery it should say 40% and not 50%. You may have missed something between 30% and 40%, it you can see it and find something error you can repair it and upload here to test it.
Avatar de Usuario
Contactar:
Mensaje por asoo »
alexstam78 escribió: 17 Dic 2021, 09:34
I have checked everything.
Using 10 images to display 100 levels and not knowing exactly how the watch is calculated. I thought I can only do like this.
The GTR3 doesn't display properly too. Most will be used only as a color bar in the show.
In the editor, it doesn't show same in clock too. So I can only do this.
Avatar de Usuario
alexstam78
Ok then probably you are right because now i have 38% and now shows 40 which is right and within the margins of error you mentioned. Thank you very much for the info, sorry and have a good day.
Responder
¿Quién está conectado?
