G284 (GTR3) asoo for GTR2
- alexstam78
- Has thanked: 173 times
Hello to community, can anyone from creators port this amazing watchaface exactly the same, only change PAI with pulse for GTR2? I post this because asoo stop make watchfaces for GTR2. Thank you very much to all creators and to asoo for his work.
https://amazfitwatchfaces.com/gtr/view/19920
- Has thanked: 441 times
OK, probably no one does.
Let's just say, I will made it, but it might not be tested on a real device.
If the watch face there are any issue or want to change something , I ask that , please try to fix or modify it by yourself.
- alexstam78
Thank you so much, asoo, I test it, everything works fine. Thank you again, Merry Christmas and happy New year.
- alexstam78
I find one error, i have 39% battery and watchaface shows 50, please fix it because i don't have the skills to do it, thank you so much.
May be happened but i am not sure I can not test because i do not have it.alexstam78 wrote: 17 Dec 2021, 07:25I find one error, i have 39% battery and watchaface shows 50, please fix it because i don't have the skills to do it, thank you so much.
Because using 10 images to show the approximate battery values as follows
This is an approximate value, it may be higher or lower. -+3-5%
1-10 = 10% 51-60 = 60%
11-20 = 20% 61-70 = 70%
21-30 = 30% 71-80 = 80%
31-40 = 40% 81-90 = 90%
41-50 = 50% 91-100 = 100%
I have already stated in the description.
- alexstam78
Yes of course i see the description that's why I say this, because according to your description of the battery rates since I have a 39% battery it should say 40% and not 50%. You may have missed something between 30% and 40%, it you can see it and find something error you can repair it and upload here to test it.
This is an approximate value, it may be higher or lower. -+3-5%alexstam78 wrote: 17 Dec 2021, 09:34Yes of course i see the description that's why I say this, because according to your description of the battery rates since I have a 39% battery it should say 40% and not 50%
I have checked everything.
Using 10 images to display 100 levels and not knowing exactly how the watch is calculated. I thought I can only do like this.
The GTR3 doesn't display properly too. Most will be used only as a color bar in the show.
In the editor, it doesn't show same in clock too. So I can only do this.
- alexstam78
Ok then probably you are right because now i have 38% and now shows 40 which is right and within the margins of error you mentioned. Thank you very much for the info, sorry and have a good day.
