Animated Watchface
samuraievo3
Animated Watchface
Post by samuraievo3 »
Hello evryone,
i have downloaded a knight rider from here https://amazfitwatchfaces.com/gtr/view/7859 for GTR and i was able to fit it to T Rex Pro.
My problem is that i cannot find anywhere settings for animated scanner bar and "Animation (beta)" option is greyed out.
I converted it with AmazFit_Watchface_Editor_(GTR47ToGTR2) latest version i have found here.
Any help please?
Find attached file json folder
Thank you
michael_knight_watch_v5-21115-d7b8d7471e.rar
(1.08 MiB) Downloaded 116 times
Been thanked: 1044 times
Animation does not work on the T Rex Pro (as on all recent watch models). Therefore, this tab is not active in the converter.
samuraievo3
SashaCX75 thank you for your reply.
T rex support it?
On the T Rex there is animation, on the T Rex Pro there is no animation.
samuraievo3
Last question....Do you know if Verge supports animation?
I do not know
samuraievo3
Which one supports? Anyone knows?
thunder87
Post by thunder87 »
SashaCX75 wrote: 28 Jul 2021, 13:43
Do you know what the reason is? Different chipset/hardware issue/bug/feature between T-Rex and T-Rex Pro?
Thanks in advance!
thunder87 wrote: 02 Aug 2021, 15:52
I think this question is better to ask the representative of Huami (Amazfit)
