There is really no detailed info how to??
netoper
Been thanked: 8 times
Post by netoper »
There is really no detailed info from huami and/or utility how to create watchfaces??? Any sources for this? Some tutorials, comunity discussion (forum). Whatever. Is it a secret? Otherwise these watch won't be very successful..
KoltesPunti
Post by KoltesPunti »
Its the same as the GTR - the only problem is to unpack / repack the files!
Biggie
Post by Biggie »
Strange answer... Unpacking/Packing are the most important functions to create WF. Without packing no watchface can be transferred to the watch. No common GTR tool (known in this forum) can handle a GTS bin w/o failure, and no common GTR tool can pack a JSON into a valid bin file for the GTS ! LOADING a valid bin file can be done with the "Notice & Fitness for Amazfit" App, but this is only the final step...
Biggie
Post by Biggie »
Another problem is the uncompress/compress functionality of a working GTS tool. "Original" GTS bin files are compressed and must be expanded before any try to unpack them. I have no tool found here, which can do this w/o failure.
@Koltes Punti: Most of all watchfaces currently in the GTS gallery are designed by YOU. If it is NO SECRET, please link the tools you're using and make a little tutorial with an example how to make a simple face (analog/digital) . Would you can do that?
Zulkifli
Post by Zulkifli »
Was hoping you do a tutorial and send a link here to enlighten us. 🤞
KoltesPunti
There's already a solution but only in chinese
Pinkabou
Post by Pinkabou »
KoltesPunti wrote: 15 Nov 2019, 12:59
Could you give me a link ? I love one of your watchface, but need info to edit it for my old eyes ;)
