can I use other numbers into an unpacked .bin ?
ev3c
Post by ev3c »
Hello.
I'm new in this and need some help.
I've just begin to make some changes to watchfaces I'd like.
I can unpack, modify and Pack a .bin watchface with AmazTool All 0.1.0.12 utilities, and also then
install this new .bin in my Amazfit Bip watch.
Well, I've added the month digits, also moved the day and week name, also added the seconds with the
default 200 image number reference, and also with the .bin internal 0011.pgn image number reference.
But I've tried to make the seconds numbers bigger and doesn't work right.
I can see the numbers on the WEB EDITOR, also in the resources, also when make the new .bin it creates
a .gif where I can see the seconds ok, but then, when I install the .bin into my watch the seconds doesn't appears.
The seconds only appears if I use the 200 default number images or the old 11 internal number images.
Can someone help me?
Is it not possible to use custom numbers in the seconds ?
The number size in pixels is 12x21, and it begins in the last image number used in the old .bin
The last is 0069.pgn and my new numbers are 0070.pgn to 0079.pgn
I've created these numbers resizing the 0011.pgn to 0020.pgn old image numbers with photoshop.
Has thanked: 437 times
Been thanked: 2141 times
ev3c wrote: 13 Sep 2019, 21:26
Hello.
1. Is it not possible to use custom numbers in the seconds ?
2. The number size in pixels is 12x21, and it begins in the last image number used in the old .bin
1. it's possible to use custom number.
2. After you resize or edited your image you save your image to 3 bits colors or not ?
Please send your .bin to me if you can.
ev3c
Post by ev3c »
Ok. That will be the problem.
Which tool do you use to convert images to 3bit 8 color ???
I search how to do this with photoshop and don't find it.
I there is a lot of op-line tools.
ev3c wrote: 14 Sep 2019, 13:41
Please try this amazfitbiptools to unpack and or pack the original file BIN ( Mi BIp )
https://bitbucket.org/valeronm/amazfitb ... downloads/
This tool can unpack and pack file BIN ( Mi Bip ) same as AmazTool All 0.1.0.12 but in pack process this tool will change your file.png to 3 bits color
And this https://www.mediafire.com/folder/3o37ts ... r_-_Stable
Editor for Bip use with amazfitbiptools
PS. If you use AmazTool All 0.1.0.12 to pack file jason to BIN that "file.BIN" can not unpack by amazfitbiptools because command line in jason by "AmazTool All 0.1.0.12" syntex not same amazfitbiptools
Program convert image.png to 3bits color. you can find in this link https://imagemagick.org/script/convert.php
command line to use convert.exe
Make map 3bits color.
convert xc:red xc:lime xc:blue xc:cyan xc:magenta xc:yellow xc:white xc:black -append mymap.png
convert <name input> -remap mymap.png <name output>
ev3c
Post by ev3c »
Ok asoo.
I try to do all this.
tx!
ev3c
Post by ev3c »
Hi asoo.
Finally I did it.
https://amazfitwatchfaces.com/search/bip/author/ev3c
Tx a lot !!!
