Amazfit GTR 42mm
Niiccoo27
Amazfit GTR 42mm
Post by Niiccoo27 »
Hello, Where did I find watch faces for amazfit GTR 42mm? In the catalog there are only watch faces for 47mm.
Fmcg
Post by Fmcg »
Agreed. There are only two watch faces available for the GTR. Would be nice if all GTR faces were compatible with either size.
tombraider
Post by tombraider »
now 4 available for 42 gtr, but i never managed to change watch face successfully@@
stationz
Post by stationz »
Zero watch faces for 42mm to me.
Niiccoo27
Post by Niiccoo27 »
It really has none for the 42mm in the catalog.
Do you know if the ones for 47mm are compatible with 42mm?
Realmente não tem nenhuma para o 42mm no catalogo.
vocês sabem se as para o 47mm são compatíveis com o 42mm?
MF1970
Post by MF1970 »
I also tried to install the 4 new watch faces that are newly available but i cannot manage to install them!!! Help please
oggeman
Post by oggeman »
I want to create my own watchface to GTR 42mm. But I don't know how to extract any existing .bin file to get into the image files.
I have downloaded and installed the latest Python 3.8. I also have the watchfacetool for Amazfit BIP .bin files that I have previously used for BIP watchfaces but this does not seem to work in the same way with GTR .bin files.
Can anyone please give any tips? I would really appreciate it. Thanks.
kampanita
Has thanked: 8 times
Been thanked: 7 times
Post by kampanita »
There is a simple method for converting 47mm to 42mm ->
Take the 47mm.bin file and compress it to zip format.
Go to https://wakeup.aliennation.lv/amazfit/index.php and select/upload that zip file....wait and then push the button for downloading transformed zip file.
Uncompress that zip returned by the web and there you can see a _42_packed.bin file for your GTR-42mm
So easy, so if you like a 47mm wf you only need to transform it in this way and you'll get your 42 version :D
An7
Post by An7 »
Everytime I try that site, it returns me an error on the page. Tried A LOT of different bins/zips.
Veseli
Post by Veseli »
Hi, I bought a gtr 42mm. Now, I have 3 watch faces in the watch. But I can change only two of them, the third one is always the same.. do you know something about it?!
And can I some how have the possibility to change all the 3 of them?!
Thanks for the answers!!
Antonio
Landuh
Post by Landuh »
An7 wrote: 21 Feb 2020, 14:44
Same here, always returns me an error on the page. I Tried some different bins/zips.
