Amazfit GTR 42mm
Niiccoo27
Amazfit GTR 42mm
Hello, Where did I find watch faces for amazfit GTR 42mm? In the catalog there are only watch faces for 47mm.
Fmcg
Agreed. There are only two watch faces available for the GTR. Would be nice if all GTR faces were compatible with either size.
tombraider
now 4 available for 42 gtr, but i never managed to change watch face successfully@@
Niiccoo27
It really has none for the 42mm in the catalog.
Do you know if the ones for 47mm are compatible with 42mm?
Realmente não tem nenhuma para o 42mm no catalogo.
vocês sabem se as para o 47mm são compatíveis com o 42mm?
I also tried to install the 4 new watch faces that are newly available but i cannot manage to install them!!! Help please
I want to create my own watchface to GTR 42mm. But I don't know how to extract any existing .bin file to get into the image files.
I have downloaded and installed the latest Python 3.8. I also have the watchfacetool for Amazfit BIP .bin files that I have previously used for BIP watchfaces but this does not seem to work in the same way with GTR .bin files.
Can anyone please give any tips? I would really appreciate it. Thanks.
kampanita
- Has thanked: 8 times
- Been thanked: 7 times
There is a simple method for converting 47mm to 42mm ->
Take the 47mm.bin file and compress it to zip format.
Go to https://wakeup.aliennation.lv/amazfit/index.php and select/upload that zip file....wait and then push the button for downloading transformed zip file.
Uncompress that zip returned by the web and there you can see a _42_packed.bin file for your GTR-42mm
So easy, so if you like a 47mm wf you only need to transform it in this way and you'll get your 42 version
Everytime I try that site, it returns me an error on the page. Tried A LOT of different bins/zips.
Hi, I bought a gtr 42mm. Now, I have 3 watch faces in the watch. But I can change only two of them, the third one is always the same.. do you know something about it?!
And can I some how have the possibility to change all the 3 of them?!
Thanks for the answers!!
Antonio
Antonio
Landuh
Same here, always returns me an error on the page. I Tried some different bins/zips.An7 wrote: 21 Feb 2020, 14:44Everytime I try that site, it returns me an error on the page. Tried A LOT of different bins/zips.
