CHANGE COLOUR
Bloccato
porcospino
CHANGE COLOUR
Messaggio da porcospino »
Hallo,
I’d like to change the colour of a watch face https://amazfitwatchfaces.com/mi-band-4/view/3079 (simplicity_ita_v1-51102-42b1fdff1a.bin).
It’s possible to edit it?
Has thanked: 1160 times
Been thanked: 278 times
Messaggio da GIK-Team »
porcospino ha scritto: 04 set 2019, 19:43
Hallo,
Write to the author in the comments https://amazfitwatchfaces.com/mi-band-4/view/3079 , maybe he will change the color for you. ;)
ilCosmico
Messaggio da ilCosmico »
You can also download the .bin file, extract it with the MiBandWFTool, edit the image named 0000.png with the color you want and repacked it with the same tool.
If the author did not reply to you yet, please write here what's the color you want... I can make the change for you ;)
porcospino
Thanks, you’re so kind.
I like acid yellow, neon yellow, fluo yellow.
Can you help me?
ilCosmico
Color like this?
https://encycolorpedia.com/faed27
Knowing RGB values would be nice :)
BTW do you mean background color, right?
porcospino
I like TITANIUM YELLOW (#eee600) for text and numbers, on black background.
thanks
ilCosmico
porcospino
great !!!!! 😃
porcospino
Hallo Cosmico,
I have installed the new face, but the battery and other icons are white, not yellow.
Could you also add the battery percentage?
Thanks so much 😊
ilCosmico
Icons now are yellow, please download it again.
Regarding the battery percentage, I'll try to add it in the next days... stay tuned :)
porcospino
ilCosmico
WF updated with battery percentage!
porcospino
excellent work !!!
thanks
porcospino
last question for you...🤗
Is it possible to enlarge a little the icon and the percentage of the battery?
now I can't see it well...
thank you
Tibor
Messaggio da Tibor »
Hi! Can someone to change the color to pastel please. Thank you very much! https://amazfitwatchfaces.com/mi-band-4/view/10708
Bloccato
Torna a “Closed topics”
