CHANGE COLOUR
porcospino
CHANGE COLOUR
Hallo,
I’d like to change the colour of a watch face https://amazfitwatchfaces.com/mi-band-4/view/3079 (simplicity_ita_v1-51102-42b1fdff1a.bin).
It’s possible to edit it?
- GIK-Team
- root
- Has thanked: 1181 times
- Been thanked: 281 times
Write to the author in the comments https://amazfitwatchfaces.com/mi-band-4/view/3079 , maybe he will change the color for you.porcospino wrote: 04 Sep 2019, 19:43Hallo,
You can also download the .bin file, extract it with the MiBandWFTool, edit the image named 0000.png with the color you want and repacked it with the same tool.
If the author did not reply to you yet, please write here what's the color you want... I can make the change for you
porcospino
Thanks, you’re so kind.
I like acid yellow, neon yellow, fluo yellow.
Can you help me?
Can you help me?
Color like this?
https://encycolorpedia.com/faed27
Knowing RGB values would be nice
BTW do you mean background color, right?
porcospino
I like TITANIUM YELLOW (#eee600) for text and numbers, on black background.
thanks
thanks
porcospino
porcospino
Hallo Cosmico,
I have installed the new face, but the battery and other icons are white, not yellow.
Could you also add the battery percentage?
Thanks so much
Thanks so much
Icons now are yellow, please download it again.
Regarding the battery percentage, I'll try to add it in the next days... stay tuned
porcospino
porcospino
porcospino
last question for you...
Is it possible to enlarge a little the icon and the percentage of the battery?
now I can't see it well...
thank you
thank you
Hi! Can someone to change the color to pastel please. Thank you very much! https://amazfitwatchfaces.com/mi-band-4/view/10708
