How to make the text grow to the left?
afm
Post by afm »
Hi, I have a little doubt. I am editing a theme for my miband 4. I want the number of steps (which is located in the right corner) when adding one more digit (for example from 999 to 1000) the numbers move to the left and not to the right , as it exits the screen. I thought that putting the alignment on the right would be solved, but it still looks bad.
Thanks and best regards.
lazimk
Post by lazimk »
I think, u need to first fix X2,Y2 (Bottom Right) coordinate and then BoxWidth or X,Y taking your expected 5 digit (for steps) bounding box (textbox) into account. Then use 'TopRight' or 'Right' alignment.
This will work!
-Laz
*Have a great day*
matrix
Post by matrix »
Пр! Я еще неготов позже спробую перейду ПК, на смартфоне не подерживается спасибо попробуем
mysiak
Has thanked: 11 times
Post by mysiak »
Have you solved this? I'm struggling with the same issue :) Thanks!
Edit: "somehow" I managed to do it with modification of X1/2 Y1/2 parameters. Not sure that I fully understand how it works, but it seems to be fine now.. :)
lumenvindex
Been thanked: 49 times
Post by lumenvindex »
Alignment to [Smth]Center and [Smth]Right works only if there is enough space between X1 and X2 (X2 must be larger than X1) for all the images that must be shown at the moment. Otherwise, images will be drawn from X1.
Same works with Y axis. Alignment to Center[Smth] or Bottom[Smth] works only if there is enough of space between Y1 and Y2. But it checks and aligns every image separately.
MESS WITH THE BEST
DIE LIKE THE REST
Users browsing this forum: No registered users and 16 guests
