how to set the time zone of the the theme
benson102057
I think the time of miband will sync when it is connecting with your phone, so maybe it depends on the time on your phone.
Also you can try "Factory Reset" first, then use 'Mi Fit' to sync.
LoraMoser
Make sure you're connected with out any VPN or proxy on your mobile, since when autosync happens, the systems reads your IP and determine ur location
