- Administrador
.bin file weight reduce
PoleoDeMenta
- Has thanked: 2 times
- Contactar:
Hi again!
I think I'm overusing this community for my questions xD, but hope they are useful for the ones who read!
I've just finished another theme, and is working correctly BUT the .bin file is 450+ kb, so I'm not able to use it on mi band 4, as I read .bin files must be at most 300kb.
Is there a way I can reduce it, so it fits on the 300kb? I'm not using a lot of images, just 64, so I don't know where to start...
Thanks again everyone who can help!
Morridin6
Without the bin file I can only guess. Some tips:
1. By adding Transparency, you must save images as 32 bit. This increases the size. If possible safe as 24 bit and do not use transparency
2. Try reducing the number of colors by using a posterize tool in your paint program. You can easily do this without actually decreasing the quality of the wf when it is shown on the miband.
3. Try making the images as small as possible. For example the steps, only create an image for the difference in each step progress and do not add the old progress. Each image in the steps progress can be placed anywhere on the image by using the right coordinates. (I have a wf in my profile that does it that way)
4. If greyscale images are used, save them as 8 bit.
PoleoDeMenta
- Contactar:
Hi, sorry for late replyMorridin6 escribió: 09 Ago 2019, 16:58Without the bin file I can only guess. Some tips:
I must use transparency, as images are, basically the ones that fill the progress bar, but they're all plain colors (I dont use photo, I make icons)
I've seen my images are not as big (the biggest ones are for the battery icons, that are 300-350bytes big, the others are just 100-200b
eastsuntecords
- Contactar:
No se muy bien como funciona mi band, pero parece que con todo lo que tiene el forma una especie de película animada, o algo así para las transparencias, por eso si metes imágenes negras sin transparencias apenas pasas de los 90kbs, pero con imágenes de fondo blancas o colores claros, se vuelve enorme, ya que repite ese fondo con las animaciones encima , o sea al compilar, para mover un gráfico de 10x10 no repite ese gráfico de 10x10 diez veces, sino toda la pantalla diez veces... por eso un wf de 200kbs con fondo negro si lo pones blanco se vuelve de 400kbs... aunque solo subas 5Kb de tamaño el fondo.
¿Quién está conectado?
Usuarios navegando por este Foro: No hay usuarios registrados visitando el Foro y 2 invitados
