Help For Making new Theme
Hello everyone, i have tryed to make a new theme, but it's my first time and maybe i want do something that is over my capabilities .
Is a very heavy modded theme for the mi band, and maybe i have done some mistake because i don't know how is possible to do or not. can someone watch my works and tell me what i'm doing wrong?
I have attached all the file that i have used.
Thanks in advance and sorry for my bad english!
- Attachments
DSWF.7z- (668.7 KiB) Downloaded 164 times
lvpokka
- Has thanked: 19 times
- Been thanked: 152 times
Here your using wallpaper as images for AMPM, create resource images 1x1 and use them here
Probably will not work with 7 days, please use 21 instead, also with 1x1 images
first elemetn Text should be all nulls, its not used
Not sure but Icon -> ImagesCount should be 9
images 28 ,29 should be used or removed
image 51 should be drawn on background and remove it
All images should be from 0000 -> X with out missing numbers
"DayAmPm": {
"TopLeftX": 0,
"TopLeftY": 0,
"ImageIndexAMCN": 0,
"ImageIndexPMCN": 0,
"ImageIndexAMEN": 0,
"ImageIndexPMEN": 0
}Code: Select all
"WeekDay": {
"X": 40,
"Y": 70,
"ImageIndex": 21,
"ImagesCount": 7Code: Select all
"Battery": {
"Text": {images 28 ,29 should be used or removed
Thank you! I have made the changes that you have suggest, ecept for the 21 days of week. It's seem that now it work better except for 2 things.lvpokka wrote: 12 Jul 2019, 22:57Here your using wallpaper as images for AMPM, create resource images 1x1 and use them hereProbably will not work with 7 days, please use 21 instead, also with 1x1 imagesCode: Select all
"DayAmPm": { "TopLeftX": 0, "TopLeftY": 0, "ImageIndexAMCN": 0, "ImageIndexPMCN": 0, "ImageIndexAMEN": 0, "ImageIndexPMEN": 0 }first elemetn Text should be all nulls, its not usedCode: Select all
"WeekDay": { "X": 40, "Y": 70, "ImageIndex": 21, "ImagesCount": 7Not sure but Icon -> ImagesCount should be 9Code: Select all
"Battery": { "Text": {
First, for some reason the background image that is 120x240 in the preview gif is upscaled and don't work properly and the animation images is upscaled too.
Second, the battery bar is smaller than the original image. There is a sort of maximun dimension?
UPDATE: ok, for some reason the image that i have used does't work, maybe i have done some mistake to the 8bit-rgb color, so i used some images from another theme ad adaped for mine, and all works now. The battery icon can be set to 10 i have tryed and now works fine.
There is only one problem left, the size of te .bin file is more large of 300Kb there is a way to "compress" all?
- Attachments
DSWFv2.7z- (752.02 KiB) Downloaded 137 times
DavidTasty
Thanks Scotty435
Now what i need is to know what kind of filtration/ filtration system/s to use. I am hearing about the mineralization tanks and clarifying tanks, can someone please enlighten me, thanks in advance
