battery drain on mi band 4
since i installed the first unofficial watch faces i have noticed that the band consume over 20% of battery per day, until i restored an official watch face. Now the situation seem to be stable.
any ideas?
any ideas?
- osmat
- Admin
- Has thanked: 35 times
- Been thanked: 73 times
What exactly watch faces did you use?M.Casper wrote: 08 Jul 2019, 17:45since i installed the first unofficial watch faces i have noticed that the band consume over 20% of battery per day, until i restored an official watch face. Now the situation seem to be stable.
any ideas?
this one: https://amazfitwatchfaces.com/mi-band-4/view/578
made by myself, supposed to be a battery proof watchfaces
Showing Pulse on WF is battery draining.
Because it looks like each time you try to see the value, it launch Mi Band's Pulse calculation = battery drain
lvpokka
- Has thanked: 19 times
- Been thanked: 152 times
290 KB!!!! i have 60kb))) limit is 350kb
[mention]huffmars[/mention] looks like there is some connection with huge images which miband have to parse every time and layout... so search for lighter one or repack this one
gdomanguera
@lvpokka is the battery life highly dependent on the size of the bin file? I know that the size of the bin file will depend on images.lvpokka wrote: 16 Jul 2019, 13:30290 KB!!!! i have 60kb))) limit is 350kb
@huffmars looks like there is some connection with huge images which miband have to parse every time and layout... so search for lighter one or repack this one
Will the features (pulse, calories, steps, distance, time, date etc.) on the WF also drain the battery faster?
Example: WF with only time displayed will it less drain the battery than a WF with time, steps and pulse?
YAESTOYAKI
El último firmware se bebe la batería en 4 días con un uso normal, cada 4 horas 5% de batería menos increíble el nuevo firmware, espero lo solucionen rápido.
YAESTOYAKI
The latest firmware is drunk the battery in 4 days with normal use, every 4 hours 5% less incredible battery the new firmware, I hope they solve it fast.
FoxForceFive
They're about the same figures as I've been experiencing, the battery life is shocking at the moment.YAESTOYAKI wrote: 21 Jul 2019, 14:16The latest firmware is drunk the battery in 4 days with normal use, every 4 hours 5% less incredible battery the new firmware, I hope they solve it fast.
Hopefully a new firmware sorts it, & soon!
Morridin6
I’m experiencing the same problems with the battery drain. I now suspect the app I use to upload watchfaces to the band is the cause. It keeps the connection open and does something that drains the battery. (I’m using AmazTools on iOS).
Last night in 6 hours 10% drain. A few days ago 40% drain in 24 hours.
Unpairing the mi band and pairing again seems to solve it for me. Now the last 4 hours only 1% drain, with a custom watch face installed.
Quasarzx12
Reboot Mi Band 4.
I also had battery drain after install my Watchface that as animations, and just reboot in Options.
It worked for me.
It worked for me.
Morridin6
Rebooting the device is even better I think. But don't forget to close the AmazTools app. You never know what it does on the background after the band is rebooted.
Quasarzx12
My smartphone is Android, so no AmazTools.Morridin6 wrote: 31 Jul 2019, 19:03Rebooting the device is even better I think. But don't forget to close the AmazTools app. You never know what it does on the background after the band is rebooted.
avyakth05
My Mi band 4 battery hardly lasts a day now......It started with battery life of 4 days at max.. then kept on reducing... Solutions??
