Mi Band 4 Theme file Unpack
mybabysexy
Post by mybabysexy »
Hi, I got these files from a theme downloaded from Mi Fit app. It consists of 3 files:
JPG for thumbnail
infos.xml: as it's name, for infomations such as name and timestamp
BIN file: like Amazfit
So can anyone decompress/unpack that BIN file? I tried AmazFit tool but no luck
Debug|Opening watch face 'E:\HP\Downloads\Compressed\AmazfitBipTools-1.0.3.1\lpGyKU3x3sCw11AgSTzgQS0MRF6ksDZUX6Kjp2lh.bin'
Debug|Reading parameters...
Trace|Reading header...
Trace|Header was read:
Trace|Signature: HMDIAL , Unknown: 68, ParametersSize: 37, IsValid: True
Trace|Reading parameter offsets...
Trace|Parameter offsets were read from file
Trace|Reading parameters descriptor...
Trace|1 (0A): 5 bytes
Trace|    1 (08): 194 (C2)
Trace|    2 (10): 88 (58)
Trace|Parameters descriptor was read:
Trace|ParametrsTableLength: 194, ImagesCount: 88
Trace|Reading parameters locations...
Trace|2 (12): 4 bytes
Trace|    1 (08): 0 (00)
Trace|    2 (10): 8 (08)
Trace|3 (1A): 4 bytes
Trace|    1 (08): 8 (08)
Trace|    2 (10): 44 (2C)
Trace|4 (22): 4 bytes
Trace|    1 (08): 104 (68)
Trace|    2 (10): 22 (16)
Trace|5 (2A): 4 bytes
Trace|    1 (08): 52 (34)
Trace|    2 (10): 52 (34)
Trace|8 (42): 4 bytes
Trace|    1 (08): 126 (7E)
Trace|    2 (10): 68 (44)
Trace|Watch face parameters locations were read:
Trace|Reading descriptor for parameter 2
Trace|Descriptor offset: 0, Descriptor length: 8
Trace|Parsing descriptor for parameter 2...
Trace|1 (0A): 6 bytes
Trace|    2 (10): 0 (00)
Trace|    3 (18): 0 (00)
Trace|Reading descriptor for parameter 3
Trace|Descriptor offset: 8, Descriptor length: 44
Trace|Parsing descriptor for parameter 3...
Trace|1 (0A): 20 bytes
Trace|    1 (0A): 8 bytes
Trace|        1 (08): 2 (02)
Trace|        2 (10): 18 (12)
Trace|        3 (18): 1 (01)
Trace|        4 (20): 3 (03)
Trace|    2 (12): 8 bytes
Trace|        1 (08): 32 (20)
Trace|        3 (18): 4 (04)
Trace|        4 (20): 10 (0A)
Trace|2 (12): 20 bytes
Trace|        2 (10): 64 (40)
Trace|        3 (18): 14 (0E)
Trace|        4 (20): 6 (06)
Trace|        1 (08): 24 (18)
Trace|        3 (18): 20 (14)
Trace|Reading descriptor for parameter 4
Trace|Descriptor offset: 104, Descriptor length: 22
Trace|Parsing descriptor for parameter 4...
Trace|    1 (0A): 18 bytes
Trace|        1 (08): 62 (3E)
Trace|        2 (10): 213 (D5)
Trace|        3 (18): 97 (61)
Trace|        4 (20): 227 (E3)
Trace|        5 (28): 20 (14)
Trace|        6 (30): 1 (01)
Trace|        7 (38): 66 (42)
Trace|        8 (40): 10 (0A)
Trace|Reading descriptor for parameter 5
Trace|Descriptor offset: 52, Descriptor length: 52
Trace|Parsing descriptor for parameter 5...
Trace|1 (0A): 26 bytes
Trace|    2 (12): 20 bytes
Trace|        1 (0A): 16 bytes
Trace|            1 (08): 70 (46)
Trace|            2 (10): 25 (19)
Trace|            3 (18): 114 (72)
Trace|            4 (20): 39 (27)
Trace|            7 (38): 30 (1E)
Trace|        2 (10): 40 (28)
Trace|    4 (20): 1 (01)
Trace|2 (12): 8 bytes
Trace|    1 (08): 72 (48)
Trace|    2 (10): 42 (2A)
Trace|    3 (18): 41 (29)
Trace|    4 (20): 21 (15)
Trace|3 (1A): 12 bytes
Trace|    2 (10): 98 (62)
Trace|    3 (18): 62 (3E)
Trace|    4 (20): 63 (3F)
Trace|    5 (28): 64 (40)
Trace|    6 (30): 65 (41)
Trace|Reading descriptor for parameter 8
Trace|Descriptor offset: 126, Descriptor length: 68
Trace|Parsing descriptor for parameter 8...
Trace|1 (0A): 14 bytes
Trace|    1 (0A): 10 bytes
Trace|        2 (10): 2 (02)
Trace|        3 (18): 17 (11)
Trace|        4 (20): 2 (02)
Trace|        5 (28): 1 (01)
Trace|    2 (10): 77 (4D)
Trace|2 (12): 14 bytes
Trace|        1 (08): 36 (24)
Trace|    2 (10): 78 (4E)
Trace|3 (1A): 14 bytes
Trace|        1 (08): 19 (13)
Trace|        3 (18): 12 (0C)
Trace|    3 (18): 76 (4C)
Trace|4 (22): 18 bytes
Trace|    1 (0A): 6 bytes
Trace|    3 (1A): 8 bytes
Trace|        1 (08): 98 (62)
Trace|        3 (18): 79 (4F)
Trace|        4 (20): 9 (09)
Trace|Reading resources offsets table with 88 elements (352 bytes)
Debug|Reading 88 images...
Trace|Image 0 offset is 0...
Debug|Reading image 0...
Trace|Reading image header...
Trace|Image header was read:
Trace|Width: 120, Height: 240, RowLength: 120
Trace|BPP: 8, PaletteColors: 256, Transaparency: False
Trace|Reading palette...
Trace|Palette item 0: R 00, G 00, B 00
Trace|Palette item 1: R 00, G 00, B 00
Trace|Palette item 2: R 00, G 00, B 00
Trace|Palette item 3: R 00, G 00, B 00
Warn|Palette item 4: R C7, G 48, B 36, color isn't supported!
Has thanked: 1180 times
Been thanked: 281 times
mybabysexy wrote: 18 Jun 2019, 04:54
We wrote to the author of the unpacking tool and waiting for an answer.
mybabysexy
GIK-Team wrote: 18 Jun 2019, 05:09
Thanks. Hoping to change the theme soon
Irfan902
Post by Irfan902 »
Does the author replied?
Irfan902 wrote: 21 Jun 2019, 03:56
He does not have Mi Band 4 and so far he can not say anything concrete. :cry:
mybabysexy
GIK-Team wrote: 21 Jun 2019, 05:21
that's bad
bjk8kds
Has thanked: 12 times
Post by bjk8kds »
Anyone wanna buy mi band 4 for him? 😁
