How do I make the new bin file containing the edited json file?
rdloach
Post by rdloach »
I have succeeded in unpacking a bin file with AmazfitBipTools-1.0.3.1 and in editing the json file with the online watchface editor for bip watch faces.
I exported the edited json file to the folder of the unpacked bin file.
Now, how do I make the new bin file containing the edited json file?
I have done web searches and can find nothing that helps me repack all the things in the folder to make a new bin file. I know it must be possible because people are doing it many times a day to keep uploading watch faces to amazfitwatchfaces !
Any help would be greatly appreciated.
TXK
Has thanked: 149 times
Been thanked: 97 times
Post by TXK »
unpacking:
DOS command window
[unpack TOOL name].EXE [File name].bin
or
[Drag and drop] bin file to [unpack TOOL name].EXE
packing:
DOS command window
[unpack TOOL name].EXE [File directory name]\YOUR.json
or
[Drag and drop] json file to [unpack TOOL name].EXE
rdloach
Post by rdloach »
I did that, TXK, but all I get is a text file called [face_name_packed].txt
I need it to turn into a file called [face_name].bin that works like all the other bin files that are uploaded.
TXK
Post by TXK »
rdloach wrote: 15 Jun 2019, 11:08
Replace the old JSON file with the new JSON file.
[Drag and drop] [NEW]. JSON file to [unpack TOOL]. EXE
If you add new functions, please download the [RESOURCES] files used for the new functions and save them in the [dial directory]
rdloach
Post by rdloach »
Thanks, TXK! I changed a WF from 24hr to 12hr. Once I uploaded the images for AM and PM, it worked like a charm!
Rob
