App doesn't connect
gcarvelli
App doesn't connect
Hi, I installed watch app on my Pace (now I have an app called Receiver watch and if I touch it, it says ver 1.0.9 service working) and I installed Amazfaces app on my android (honor 9 lite phone with android 9). I activated bluetooth, but if I select a watchface on phone and I touch download it says "download app for watch".
What's wrong?
Thank you
What's wrong?
Thank you
gcarvelli
Thank's for your answer. I rebooted watch but it doesn't work. If I go in the corner up right / change device / Stratos Pace / Connect i got message "download app for watch". Same if I select Download on a watchface.
I attach screenshot of watch and phone.
What I'm doing wrong?
Thank you
Thank you
- Attachments
- IMG_20190603_095635.jpg (103.07 KiB) Viewed 12084 times
- Screenshot_20190603_095817_com.amazfitwatchfaces.st.jpg (287.57 KiB) Viewed 12084 times
- GIK-Team
- root
- Has thanked: 1181 times
- Been thanked: 281 times
Try this service app: https://amazfitwatchfaces.com/api/app/a ... pp_111.apkgcarvelli wrote: 03 Jun 2019, 08:02Thank's for your answer. I rebooted watch but it doesn't work. If I go in the corner up right / change device / Stratos Pace / Connect i got message "download app for watch". Same if I select Download on a watchface.
Thank you
gcarvelli
- GIK-Team
- root
Did you install Amazfit Watch? And does it work normally (our application uses the Amazfit Watch connection)? https://play.google.com/store/apps/deta ... tchmanagergcarvelli wrote: 04 Jun 2019, 21:01Now is 1.0.11, is working but has same problem.
Help please.
Thank you
gcarvelli
gcarvelli
On the clock there are only stock apps; AW is the first app I installed on watch by myself.
Reconnect doesn't work, nothing happens. If I click download it goes on download pages, if I click on skip it says "watch not connected". Reconnect doesn't work.
Bluetooth is on both on watch and phone, amazfit app works fine ...
Thank you
Thank you
faca9
Hello guys,
first I want to say you are doing amazing job here. Now,
I have the same problem, can't connect, so I'll write here not to double this post.
Phone OnePlus 6, FW 9.0.8
Stratos, ROM 2.3.10.5
on the watch service running v1.0.12.
Have already tried things mentioned before in this post (rebooting, ...). Still no connection.
Amazfit App and Mi Fit connects no problem.
Any ideas?
Any ideas?
faca9
So never mind, I was just pressing connect until connection was made. Now it's working...
