App doesn't connect
gcarvelli
App doesn't connect
Post by gcarvelli »
Hi, I installed watch app on my Pace (now I have an app called Receiver watch and if I touch it, it says ver 1.0.9 service working) and I installed Amazfaces app on my android (honor 9 lite phone with android 9). I activated bluetooth, but if I select a watchface on phone and I touch download it says "download app for watch".
What's wrong?
Thank you
osmat
Admin
Has thanked: 35 times
Been thanked: 73 times
Post by osmat »
Reboot the clock. And reconnect them in the Amazfaces app.
gcarvelli
Post by gcarvelli »
Thank's for your answer. I rebooted watch but it doesn't work. If I go in the corner up right / change device / Stratos Pace / Connect i got message "download app for watch". Same if I select Download on a watchface.
I attach screenshot of watch and phone.
What I'm doing wrong?
Thank you
Has thanked: 1181 times
Been thanked: 281 times
gcarvelli wrote: 03 Jun 2019, 08:02
Thank you
Try this service app: https://amazfitwatchfaces.com/api/app/a ... pp_111.apk
gcarvelli
Post by gcarvelli »
Now is 1.0.11, is working but has same problem.
Help please.
Thank you
gcarvelli wrote: 04 Jun 2019, 21:01
Help please.
Thank you
Did you install Amazfit Watch? And does it work normally (our application uses the Amazfit Watch connection)? https://play.google.com/store/apps/deta ... tchmanager
gcarvelli
Post by gcarvelli »
Yes, I have Amazfit Watch on my smartphone and it works fine.
osmat
Admin
Post by osmat »
What programs are still installed on the clock besides ours? Did you try to click reconnect?
gcarvelli
Post by gcarvelli »
On the clock there are only stock apps; AW is the first app I installed on watch by myself.
Reconnect doesn't work, nothing happens. If I click download it goes on download pages, if I click on skip it says "watch not connected". Reconnect doesn't work.
Bluetooth is on both on watch and phone, amazfit app works fine ...
Thank you
osmat
Admin
Post by osmat »
Install this beta version of our app on your phone. Your watch should have the latest service 1.0.11 installed.
faca9
Post by faca9 »
Hello guys,
first I want to say you are doing amazing job here. Now,
I have the same problem, can't connect, so I'll write here not to double this post.
Phone OnePlus 6, FW 9.0.8
Stratos, ROM 2.3.10.5
on the watch service running v1.0.12.
Have already tried things mentioned before in this post (rebooting, ...). Still no connection.
Amazfit App and Mi Fit connects no problem.
Any ideas?
faca9
Post by faca9 »
So never mind, I was just pressing connect until connection was made. Now it's working... :)
