bin extractor errors with Fatal|System.ArgumentException
bastens_com
I am attempting to edit an existing watch face. I started with trying to extract the the bin file using Amazfit Tools WatchFace.exe (dragging the bin file on the executable) but I get an error:
Trace|6 'Weather'
Trace|6.1 'WeatherIcon'
Fatal|System.ArgumentException: Parameter 2 isn't supported for WeatherIcon
at WatchFace.Parser.Utils.ParametersConverter.Parse[T](List`1 descriptor, String path)
at WatchFace.Program.ParseResources(Reader reader)
What am I doing wrong?
Trace|6 'Weather'
You may not be doing anything wrong.
Can you provide (or tell me where to download) the watchface bin file?
If so, I will try to extract it and see what happens.
Regards,
Eric
Regards,
Eric
bastens_com
Thank you for your reply and for your time. I tried this on two with the same results:
amazfitwatchfaces ... /bip/view/7825 (Seiko G757 v7 12h with 24 Dual Time Zones)
amazfitwatchfaces ... /bip/view/3644 (Falcon Heavy V2 ENG)
Cheers,
Pat
Cheers,
Pat
- TXK
- Has thanked: 149 times
- Been thanked: 97 times
Download the latest version of unpacking software:
https://bitbucket.org/valeronm/amazfitb ... downloads/
Hi Pat,
I used the latest version of Amazfit BIP tools (AmazfitBipTools-1.0.3.1.7z) and both of the watchfaces you listed extracted without problems. If you aren't using the latest version, give that a try.
Regards,
Eric
Regards,
Eric
bastens_com
Oh my it was that simple, it worked as it should.
Thank you!
Thank you!
