Watchface from Verge to Stratos
Diothorn
Post by Diothorn »
Hi guys,
New to the forums. I saw this amazing watchface for Verge (机械金属 by GIK-Team ) and i want it to use it with Stratos.
I used the converter but some parts of the widgets are not alligned correctly. Is there a way or someone that can help me fix this watchface so it can be perfect and ready to use with Stratos?
Has thanked: 1179 times
Been thanked: 281 times
Diothorn wrote: 22 Mar 2019, 16:18
Hi guys,
This does not give a 100% guarantee of the correct display of all elements.
Unfortunately. Some parts need to correct by hands. Try post it here, maybe someone will fix it.
Diothorn
Post by Diothorn »
Ok sure...this is the one i added as an attachment
stratos_5c955ba1cf464.wfz
The watchface i mentioned
(1004.92 KiB) Downloaded 195 times
Diothorn
Post by Diothorn »
Any help will be highly appreciated
TXK
Has thanked: 150 times
Been thanked: 99 times
Post by TXK »
Diothorn wrote: 23 Mar 2019, 10:25
1、I don't have a Stratos Watch
2、Modify the dial using a virtual tool
3、There may be an error in the dial file.
englishWeek-TEST.wfz
(1012.68 KiB) Downloaded 179 times
chineseWeek-TEST.wfz
(1012.68 KiB) Downloaded 147 times
Parameter .jpg (103.66 KiB) Viewed 3906 times
Parameter effect.jpg (271.1 KiB) Viewed 3905 times
Diothorn
Post by Diothorn »
Thank you very much for the help. I will do my best to fix it
TXK
Post by TXK »
Diothorn wrote: 24 Mar 2019, 00:22
A question:
Will the following two beta versions work properly?
Diothorn
Post by Diothorn »
TXK wrote: 24 Mar 2019, 04:13
A question:
Hi dude,
The English version works great it just, in my opinion, needs the date more to the left, without italics and in white colour. Currently it is displayed like the picture below.
Thank you
Diothorn
Post by Diothorn »
Diothorn
Post by Diothorn »
I also tried the chinese test verion. It is perfect...no fixes needed :D
TXK
Post by TXK »
Diothorn wrote: 25 Mar 2019, 09:15
<WatchFaceItem type="datawidget" id="3" x="108" y="55" width="120" height="21" dataType="6" model="6" mask="@wfz/datawidget/mask_3_fg.png" configList="@wfz/digitaldate_list.xml"/>
1. Modifiy Date X coordinates reduced by about 25 pixels: (108-25 =83)
2. If you don't like tilted fonts, please choose another mode. ( Modifiy model="6" ---- Select from the following image )
Diothorn
Post by Diothorn »
Thank you
