Garmin watchface for gtr4
Has thanked: 115 times
Hi, would someone make this Garmin watchface for gtr4?
Can the feature on top left next to steps count be distance in miles?
Can the blue color be switchable with some other colors like brown, grey, dark orange, dark red and olive green or army green?
https://apps.garmin.com/apps/52fc9617-8 ... 71e619678a
Has thanked: 437 times
Been thanked: 2140 times
Wahwah wrote: 02 Aug 2026, 20:54
Hi, would someone make this Garmin watchface for gtrt?
As I mentioned before, if you require a specific color, I recommend providing a color sample and/or at least a hexadecimal color code, as everyone's perception of color shades is different. For example, the dark red you desire may appear darker to one person than another.
Also, I'm unsure which device you intend to use it with. You mentioned GTRT, and as far as I know, there is no such device. I assume you are referring to the GTR4 you previously requested, correct?
This dial isn't difficult to create if I were to undertake the work, but please specify the model and provide a color sample of your desired shade, as I do not wish to alter the colors once completed.
I tried to attach some images of color samples put it didn’t let me so i attached them to the original post. Sorry for the typo yeah it is for gtr4
Thank you for creating the watchface.
The colors don’t have to be exact if it is not possible similar will be fine as well
Kilometers and miles will be displayed as set in the Zepp app.
Gamin_Enduro3_GTR_4.zip
(463.84 KiB) Downloaded 10 times
It is perfect thank you so much
