T Rex 3 Watch face request PLEASE! [T-REX 3]
luciaswew32
Post by luciaswew32 »
Hey,
i just moved over from a huawei. i had this watch face there which i cannot find here at all. i got it from a huawei watch group on telegram. I have the HWT file of it as well as i am attaching an image here. if any of that can help. Please create this one/convert it for the trex 3, i havent been able to make it on the watch creator :cry: :cry: :cry:
if you need the hwt file let me know i ll send that as well, thanks!
MarioLie
Has thanked: 53 times
Been thanked: 37 times
Post by MarioLie »
I'll create it for you, with minor changes if you don't mind.
Preview
Down:https://amazfitwatchfaces.com/t-rex/view/18823
Has thanked: 426 times
Been thanked: 2131 times
luciaswew32 wrote: 12 Jun 2026, 10:20
Hey,
I made this for Balance, which has the same screen size as the T-Rex3.
It should work with your T-Rex3.
If you're interested, check it out at
Preview
https://amazfitwatchfaces.com/balance/view/7824
Note :
The Heart Rate Graph will be displayed when there is enough data for the day.
If you have just put on your watch, the graph will not display until there is enough Heart Rate data (at least 1 hour after you put on the watch and the watch has received your Heart Rate data).
The Heart Rate Graph resets daily at 00:00 and will start displaying again after receiving the data for the new day.
