Request Balance 2 Default Watch Face for Active 2 Round
Been months looking and trying to download or design default Balance 2 watch face to Active 2 Square. Help anyone?
- Has thanked: 420 times
- Been thanked: 2122 times
I'm not entirely sure if you want Round or Square.
Your title says:
"Request Balance 2 Default Watch Face for Active 2 Round"
but your post says:
"Balance 2 watch face to Active 2 Square." If you mean you want to manually change Active 2 Round to Active 2 Square, you could check this out:
https://amazfitwatchfaces.com/gtr/view/43092
This is a GTR4 watch face, which is the same size as Active 2 Round and is interchangeable.
However, the original watch face is encrypted, so the suggested GTR4 watch face has been recreated by the creator(Avoska1988), and some widgets may not same the original.
This GTR4 watchface contains a custom script.
Therefore, if you unpack it with an editor, some widgets created from that custom script might not display.
However, you will get a basic structure that should allow you to further develop it to your needs,
