Request help to Convert GTS2 to GTS2 mini Watchface
losterrr
Post by losterrr »
Hello everyone!
I'm requesting a conversion of a watch face from GTS 2 to GTS 2 Mini.
Watch face: The Division (SHD Agent)
Original device: GTS 2 >> Target device: GTS 2 Mini
I've been looking for a version of this watch face compatible with the GTS 2 Mini for a while, but unfortunately I couldn't find one in the catalog. I've tried to convert it to GTS mini 2 myself but without success
Thank you in advance!
https://amazfitwatchfaces.com/gts/view/4959
Been thanked: 2122 times
losterrr wrote: 19 Mar 2026, 11:41
Hello everyone!
This watch face I have not tested with real devices because I do not have it.
All creations are tested with the program used to create it.
If the watch face does not work as shown in the sample image, I cannot make any additional changes.
Those who test it, please manage the risk by yourself.
You can find the device used to create the watch face at
viewtopic.php?p=12537#p12537
Note for this watchface :
The original watch face uses full-screen images to display the bezel that changes with the seconds. Therefore, there are up to 10 large images, the convert to GTS2mini it making the watchface file very large. I'm not sure if the GTS2mini has a limit on watchface file size, and I couldn't test it because I don't have a GTS2mini. All testing was done using an editor only.
Therefore, please manage your own risk when using this.
Some widgets don't resemble the original because they are not available in the GTS2mini editor.
shd_packed.bin
(4.23 MiB) Downloaded 46 times
